POV-Ray : Newsgroups : povray.binaries.images : Fluorapophyllite-(K) : Re: Fluorapophyllite-(K) Server Time
26 Mar 2026 20:27:02 EDT (-0400)
Date: 11 Nov 2021 11:44:14
Message: <618d485e@news.povray.org>
Le 2021-11-10 à 17:06, Samuel B. a écrit :
>> Op 09/11/2021 om 20:02 schreef Kenneth:
>>> BTW, I did not realize that an object with ior could have inclusions (other
>>> objects) with *different* ior's-- I thought such constructs would be an example
>>> of 'variable' ior within an object, which cannot be accomplished in POV-ray,
>>> AFAIU. I had a mistaken notion that the camera ray would 'see' the outer object
>>> surface first, (...)
>> To tell the truth, I really do not know /how/ the different ior's are
>> treated together. Afaik, this is not explained in the wiki pages. To
>> keep on the safe side, I kept the inclusion's ior at 1.0 which is
>> cheating of course, but at least I was not confronted to strange
>> effects.
> If I'm not mistaken, a ray evaluates all objects and their iors along its path
> and changes its trajectory accordingly. So in a union, it is not really
> 'cheating' to have objects with an ior of 1 inside. They are treated as air
> until the ray moves on. It's a reasonable alternative to using a difference
> which - while not requiring objects with different iors - is very slow to trace.
> Oh, and a while back, I found out that if you want to pretend that the camera is
> inside some volume, say water, and you want to see air bubbles in that volume,
> then for the air bubbles you would use the reciprocal of water's ior. So, the
> bubbles would have an ior of 1/1.325, iinm.
> Sam
If you want to use a difference, then, you should use a blob instead of
100' to 1000's of spheres.
That way, you benefit from the blob's hierarchy and internal bounding
mechanism.
