POV-Ray : Newsgroups : povray.binaries.images : Luna, Moon... desert satellite : Re: Luna, Moon... desert satellite Server Time
23 Mar 2026 19:58:26 EDT (-0400)
Date: 13 Sep 2021 02:48:53
Message: <613ef455$1@news.povray.org>
Op 12/09/2021 om 22:22 schreef Samuel B.:
>> schreef Samuel B.:
>>> What's IC, btw? Did you mean IV aka IrfanView? I use that for many things, but
>>> in this case it didn't help the situation whatsoever. Maybe I'm using it wrong.
>>> Instead I used GIMP and exported the image to a png file with some options
>>> enabled.
>> That is Ive's small (but not little) application:
>> https://www.lilysoft.org/IC/ic_index.htm
> Thank you, that looks like just the ticket since it supports higher bit depths.
> (For some reason Firefox flagged the site as potentially malicious. But I
> downloaded the file, scanned it with Defender and then VirusTotal, and it turned
> up clean.)
Firefox does not react to IC here (reports it is clean) but it is never
wrong to scan web stuff. It is my standard procedure for everything
coming from outside.
I think you will like IC.
