POV-Ray : Newsgroups : povray.binaries.images : Luna, Moon... desert satellite : Re: Luna, Moon... desert satellite Server Time
21 Mar 2026 05:46:02 EDT (-0400)
Date: 12 Sep 2021 02:19:58
Message: <613d9c0e$1@news.povray.org>
Op 11/09/2021 om 22:47 schreef Samuel B.:
>> Op 11/09/2021 om 02:36 schreef Samuel B.:
>>> "Samuel B." <stb### [at] hotmailcom> wrote:
>>> (...) Maybe POV-Ray is mishandling the tiff file?
>> And if you save the tiff as tga or png (using IC which I prefer), what
>> happens?
> Well, if I save it as a png file it gets /fixed/, that's what happens! Thanks
> Thomas :D
Wow... It was just a thought. I had the dim memory that tiff might be
problematic...
> The attached is what the POV-Ray render looks like now.
Yes! That is much better indeed.
> What's IC, btw? Did you mean IV aka IrfanView? I use that for many things, but
> in this case it didn't help the situation whatsoever. Maybe I'm using it wrong.
> Instead I used GIMP and exported the image to a png file with some options
> enabled.
That is Ive's small (but not little) application:
https://www.lilysoft.org/IC/ic_index.htm
> TL;DR: use GIMP to convert NASA's tiff files to a 16-bit png file using the
> 16bpc GRAY pixel format :)
> Sam
> P.S. I still wonder if POV-Ray is mishandling 16-bit grayscale tiff files...
