POV-Ray : Newsgroups : povray.binaries.images : Documenting wrinkles normal pattern bias. v3.7/v3.8. : Re: Documenting wrinkles normal pattern bias. v3.7/v3.8. Server Time
26 Mar 2026 03:17:47 EDT (-0400)
Date: 8 May 2021 08:02:00
Message: <60967db8$1@news.povray.org>
On 5/7/21 6:54 PM, Bald Eagle wrote:
> William F Pokorny <ano### [at] anonymousorg> wrote:
> Following along in /source/core/material/normal.cpp
As I was thinking aloud I was thinking about what the base normal
perturbation pattern would see as in normal.cpp and what the base scalar
value patterns would see in pattern.cpp.
You're right more is available "up the call" chain. I have some code
partly done adding a new pattern to normal.cpp where I now pass more
information down to the base pattern. I plan to test the 'pass a 3x 21
vector' bit as an explicit normal perturbation via a function. We'll see.
Side tracked at the moment on some questions which popped to the surface
as I worked on the code.
> Not sure about the accuracy, and not clear why the pyramid is "biased".
> I had problems using the internal sum () function, but adding the 4 pyramid
> vectors by hand gave me <0, 0, 0> (out to 8 dec places) so I'm not sure what the
> bias would be.
Bias comes from the fact it's a pyramid of four scalar value evaluations
about the center intersection point (the evaluation point ie EPoint) and
not the min of 8 samples (a cube, dual pyramid, dual +, or...) which I
believe necessary for 'better balanced' sampling(1). The pyramid is
getting used for performance reasons I'd bet - and maybe we continue to
use it for this reason(2).
(1) - The reality is there are also biases coming in from shapes on raw
normal. From isosurfaces, for example, where the raw normals are
calculated with three + offsets for a 'leaning pyramid' with the EPoint
at the 'pyramid top'. My belief today is in isosurfaces this is done to
get the inside/outside surface normals pointing in the right direction
with respect to the ray/surface intersection (the at zero value), but
maybe that thinking is off?
(2) - What I've not done is look at how large the bias typically is by
coding up alternatives and measuring it! A complication is results will
be affected by the accuracy setting because often during pattern
perturbations / turbulence the 3D gradients about the EPoint are not at
all constant.
Bill P.
