POV-Ray : Newsgroups : povray.binaries.images : Whats Next : Re: Whats Next Server Time
13 Oct 2026 22:55:04 EDT (-0400)
  Re: Whats Next
Date: 13 Sep 2017 06:36:54
Message: <59b90a46$1@news.povray.org>
On 9/12/2017 7:53 AM, Norbert Kern wrote:
> Therefore I prefer hdr lighting or at least a combination of a normal
> lightsource and hdr.
here's a link to some pretty good hdr images:
http://www.hdrlabs.com/sibl/archive.html
i've been getting a lot of mileage out of papermill ruins E but playa is
also pretty cool. the apartment at the top of the list is great for an
inside env.
i prefer the ones where you can actually see the sun or light source.
basically here's how i place the light source. with the image on a small
sphere and the camera somewhere -z ... i rotate the sphere until the sun
spot lines up with 0*y then i use a crude grid at <0,0,0> that i rotate
in the x dir to get the elevation. a few hints ... the papermill ruins E
lines up at y*33 and x*30.5 so i use those as offsets in my env and
light source setup:
#declare Environment =
sphere { 0, 1 hollow on
   material {
     texture { uv_mapping
         image_map {
           hdr "PaperMill_E_3k.hdr"
           map_type 0
           interpolate 2
           once
       finish { ... }
     interior { ior 1.0 }
   rotate y*33
   no_shadow
#local R_Fact = 30;
#local S_Fact = 30;
considering the above the light source is initially placed <0,0,-29.9>
then transformed like this:
object { Environment scale S_Fact rotate y*R_Fact }
object { Key_Light rotate x*30.5 rotate y*R_Fact }
