POV-Ray : Newsgroups : povray.binaries.images : Spinner colony (again) : Re: Spinner colony (again) Server Time
25 Nov 2026 17:09:27 EST (-0500)
Date: 12 Feb 2015 18:25:47
Message: <54dd367b$1@news.povray.org>
On 2/12/2015 4:02 PM, Alain wrote:
>> Segmenting the light source would create strange shadows on the
>> interior. Not sure what you mean about the pavement and 6 sections. I
>> would like to make the light source more yellow, but haven't figured out
>> how. Here's the LightSys code I use:
>> #local Lightsys_Scene_Scale    = Meters * 100;            // 1 = 1cm?
>> #local light_lumens        = 2;                    // float
>> #local light_temp        = Daylight(6100);            // float in kelvin°
>> #local light_color        = Light_Color(light_temp, light_lumens);
> If you reduce the value for Daylight() somewhat, it will get yellower,
> and to a redish tint if you reduce it enough.
> Try something like:
> #local light_temp        = Daylight(5950);
> Alain
Here's the material for the central axis lamp. I would like it to look a
little dimmer and yellower. What should I change?
texture {pigment {gamma_color_adjust(light_color) transmit 1}}
interior
	media
		emission gamma_color_adjust(light_color)
		density
			cylindrical
			color_map
				[0 srgb 0]
				[1 srgb 1]
			scale	lamp_radius
			rotate	x * 90
