POV-Ray : Newsgroups : povray.binaries.images : Alienese : Re: Alienese Server Time
7 Nov 2026 22:29:47 EST (-0500)
  Re: Alienese
Date: 19 Sep 2010 20:58:41
Message: <4c96b1c1@news.povray.org>
Extreme example!
AlieneseWrap( 60, 60 )
It looks like code, maybe I need to add some hierarchical indenting!
(probably putting too much thought into this, should get on with the sci-fi
picture I created it for!)
Tek
http://evilsuperbrain.com
news:4c96af79@news.povray.org...
> "Christian Froeschlin" <chr### [at] chrfrde> wrote in message
> news:4c962d8c@news.povray.org...
>> Looks neat and very elegant solution! The only problem I see
>> is that the perfect grid may be a bit distracting. I just played
>> with a derived pigment that uses different spacings for each
>> line although it is not really a proportional font:
> Cool, though for my purposes I don't need a wall of text so the pattern
> should never be obvious.
> Though I did think about how to make each line be a random number of
> characters long...
> ...In fact I've given that a quick try, turns out to be pretty simple.
> Here's the code:
> #local f_cells = function { pattern { cells } }
> #macro AlieneseWrap( LineLength, Variation )
> function {
>  select( LineLength - int(f_cells(x/LineLength,y,z)*Variation) - x, 0, 1 )
> pigment_map {
>  [0 rgb 0]
>  [1 Alienese]
> #end
> pigment { AlieneseWrap( 25, 10 ) }
> Obviously this can be adapted easily to have chinese style downwards
> writing
> instead of left-to-right. Dunno what the syntax is for this language :)
> Tek
Download 'temp.png' (83 KB)
Preview of image 'temp.png'
