POV-Ray : Newsgroups : povray.binaries.images : #read: why is the second variable undeclared? : Re: #read: why is the second variable undeclared? Server Time
13 Nov 2026 04:54:45 EST (-0500)
Date: 21 Apr 2010 15:21:13
Message: <4bcf5029$1@news.povray.org>
Jörg 'Yadgar' Bleimann wrote:
> accurate representation, I divided the whole surface in 2592 (72 by 36)
> tiles, each covering 5 x 5 degrees by 1800 x 1800 pixels
Note that high resolution meshes require a lot of parse time,
so before you embark on this 8 month analysis you might wish
to verify that it will actually help your animation.
> Here is the code for the read routine
the code looks reasonable, can you post the data file
itself as you write it during the first frame?
