POV-Ray : Newsgroups : povray.binaries.images : Blurred apophysis meets traced cylinders : Re: Blurred apophysis meets traced cylinders Server Time
30 Oct 2026 14:49:55 EDT (-0400)
Date: 18 Feb 2009 12:28:31
Message: <499c453f$1@news.povray.org>
Man thats pretty cool!
Fractal Explorer (which you can program fractals in, using formula parser)
and chaoscope are both very good as well. http://www.chaoscope.org/
http://www.eclectasy.com/Fractal-Explorer/
Hmm...that makes me want to try your method on some fractals of my own.
ian
"Peter Hertel" <peter@**nospam**hertel.no> wrote in message
news:web.499c335881b8128e2611931b0@news.povray.org...
> Mid-week abstract anyone?
> Just a small test, which uses a few techniques which perhaps might be of
> interest for some?
> First, it's a simple way of randomly placing a lot of objects without them
> intersecting. The code should speak for itself, but I don't know if this
> method
> is entirely bulletproof?
> Second, I wanted to use an image I did with apophysis (
> http://www.apophysis.org/ ). The resolution was a bit too low though, and
> I
> lost the settings to remake it. So I blurred it by averaging the image
> several
> times in a while loop. I've blurred procedural textures this way before,
> but it
> works quite well with image_maps also.
> I'd love to see some "remixes" of this scene! The source is below, and I
> can
> post the background image if anyone's interested.
> (Pinnedyr means phasmatodea/walking sticks in Norwegian).
> -Peter
> // +w1920 +h1200 +a0.3
> // +w1920 +h400 +a0.3
> camera{
>        ultra_wide_angle
>        location <1,3,-5>*0.3 look_at y*1 angle 130
>        sky vrotate (<0,1,0>,z*40)
>        translate <-1,-0.5,-1>
>        right x*image_width/image_height
>        up y
> light_source{<5,15,-10>1}
> #local TO = plane{y,0} // Trace Object
> #local Radius = 0.025; // Radius of cylinders
> #local S = seed(1337);
> #local X = 0;
> #while (X<1)
>        #local Shoot_Start     =
> vrotate(<1-rand(S)*0.5,3+sin(X*4*pi)*0.1+rand(S)*0.2,0>,y*360*rand(S));
>        #local Shoot_Direction =
vrotate(<-Shoot_Start.x+rand(S)*0.1,-1.3-rand(S)*0.5,-Shoot_Start.z+rand(S)*0.1>,y*10*rand(S));
>        #local Shoot_End       = trace(TO,Shoot_Start,Shoot_Direction);
>        #if(Shoot_End.y=0) // If it hits the plane in TO
>                #ifndef(OBJ) // Final OBJect
>                        #local OBJ = merge{
>                #else
>                        #local OBJ = merge{object{OBJ}
>                #end
>                        cylinder{Shoot_Start,Shoot_End,Radius}
>                        sphere{Shoot_Start,Radius}
>                        sphere{Shoot_End,Radius}
>                #local TO =
>                union{
>                        object{TO}
>                        cylinder{Shoot_Start,Shoot_End,Radius*2} // Radius
> doubled to avoid collision
>        #end
> #local X = X+0.001; // Decrease to shoot more cylinders
> #end
> object{OBJ
>        texture{
>                pigment {rgb 0.9 filter 0.9}
>                finish{reflection {0.2,0.6} ambient 0.1 specular 0.4 phong
> 0.3
> irid{0.25 thickness 1}}
>        interior{ior 1.255 fade_color x*2 fade_power 2}
> #local AP = 0.05; // increase/decrease to blur less/more
> // These settings worked well for my 1920x1200 image_map
> sky_sphere{
>        pigment{
>        average
>                pigment_map{
>                        #local X = 0;
>                        #while (X<1)
>                                [AP+X*AP, image_map{png
> "Apophysis-081026-214_1000.png" interpolate 2 map_type 1}rotate
> y*(35+1*X)]
>                        #local X = X+AP;
>                        #end
