POV-Ray : Newsgroups : povray.binaries.images : Why is there a gap between my df3 media boxes? : Re: Why is there a gap between my df3 media boxes? Server Time
15 Oct 2026 03:11:08 EDT (-0400)
Date: 25 Apr 2008 11:02:30
Message: <4811f286$1@news.povray.org>
Martin Magnusson nous illumina en ce 2008/04/25 04:01 -->
> I'm plotting a continuous function in 3D with df3 files and media, using
> a number of boxes with media. However, at the transition between
> media-filles boxes, there are small gaps. Can someone explain why?
> Attached is a rendition of two of the boxes. The df3 files have 10x10x10
> entries. Below is the upper plane of the lower box in text format:
>      0    0    0    0    0    0    0    0    0    0
>      0    0    0    0    0    0    0    0    0    0
>      0    0    0    0    0    0    0    0    0    0
>      0    0    0    0    0    0    0    0    0    0
>      0    0    0    0    0    0    0    0    0    0
>      4    1    0    0    0    0    0    0    0    0
>     95   70   39   16    5    1    0    0    0    0
>    139  227  255  224  130   58   25    9    2    0
>     11   35   80  135  177  198  210  170  108   55
>      0    0    1    3    9   26   67  131  196  222
> And the lower plane of the upper box is:
>      0    0    0    0    0    0    0    0    0    0
>      0    0    0    0    0    0    0    0    0    0
>      0    0    0    0    0    0    0    0    0    0
>      0    0    0    0    0    0    0    0    0    0
>      0    0    0    0    0    0    0    0    0    0
>      4    1    0    0    0    0    0    0    0    0
>     94   71   40   16    5    1    0    0    0    0
>    142  233  255  232  134   60   24    8    2    0
>      9   32   75  129  172  196  207  166  102   50
>      0    0    0    2    8   23   63  128  192  216
> As far as I can see, there should be a smooth transition between the two
> boxes. Can someone explain where the gap that shows in the image comes
> from? I have also attached a scene file that renders this image.
Just use une single box twice as high and put the two media in it, translated as
needed. When you have more than one media in a container, they add toggether.
Your container and media become:
box{0,1 scale 2*z
   hollow
   pigment{ color rgbt 1 }
   interior{
     media{
       emission 1
       density{
	density_file df3 "00001325.df3"
	interpolate 0
		translate z
     media{
       emission 1
       density{
	interpolate 0
   translate <4, 4, 3>
You know you've been raytracing too long when you resign the fact that printing
uses CMYK instead of RGB to one of those tests God gave to Job; otherwise life
would be too painful to go on.
     -- Taps a.k.a. Tapio Vocadlo
