POV-Ray : Newsgroups : povray.binaries.images : Solvable because it's solvable... : Re: Solvable because it's solvable... Server Time
11 Nov 2026 14:37:34 EST (-0500)
Date: 4 Jan 2008 12:15:53
Message: <477e69c9$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote
>   "This problem is solvable" actually means that you can assume
> something about the problem, as I described in that post. Without
> knowing that it is indeed solvable it would be quite hard to prove that
> it indeed is. Would require quite complicated math.
A problem is either solvable, not solvable, or a fields medal candidate. We
can safely ignore the last possibility here I think. If you ask me a
problem/puzzle to find a solution to, and if I trust that you are not
leading me to a wild goose chase, it means it's given that it *is* solvable.
If I don't trust you, no amount of reiterating that it's solvable will
convince me ( "if ((((x=true)=true)=true..." syndrome ).
