POV-Ray : Newsgroups : povray.binaries.images : Another failed render (~300 KB) : Re: Another failed render (~300 KB) Server Time
25 Nov 2026 10:32:17 EST (-0500)
Date: 7 Oct 2006 10:47:38
Message: <4527be0a@news.povray.org>
"Orchid XP v3" <voi### [at] devnull> wrote in message
news:4527b397$1@news.povray.org...
> Cube is a placeholder, yes.
Spheres usually make better placeholders when tweaking materials IMO, the
hard edges of the cube mean you don't see how it interacts with the light at
all angles, making it very hard to tune effects like specular.
> OK. I'm currently investigating Christoph's waver macro. Seems to
> produce big fractal-like waves. (I'd actually like the ripples to
> radiate from the stone block and follow its shape eventually...)
Well if you want ripples radiating from the block why are you looking at a
macro for fractal like waves?
Radiating from a block is a bit awkward, I suggest basing it on a function,
like:
normal { function { sin(8*pi*sqrt(pow(max(x-1,0),2)+pow(max(z-1,0),2))) } }
that should give nice "distance from a square" based ripples, though if you
plan on changing the shape of your stone it might not look so good.
> The water *itself* is a fairly simple thing, as you say. It's
> transparent, refractive and reflective. So basically it doesn't look
> like anything by itself... gotta have something nice to reflect.
> My main problem seems to be getting a decent sky. :-S
Nope I disagree, if you have a realistic water material from this angle it
would be almost completely transparent, the reflection would only show up on
the top edge of the ripples (see attached picture). What's important is the
fall-off of the reflection, which should be either reflection{.01,1 falloff
5} to fake it or reflection{0,1 fresnel} if you have a realistic ior.
> I wouldn't have thought assumed_gamma 1 would have *any* effect...
> surely that just means that each colour component is raised to the power
> of 1 before being output?
Yeah that confused the hell out of me when I first encountered it. The
simple answer is that pov knows what your display gamma is, or rather it has
a default of 2.2. If you don't say "assumed_gamma" it doesn't gamma correct
from the linear colour space of the pov scene to the non-linear gamma of the
monitor. assumed_gamma essentially tells pov what the gamma space of your
scene is, which is a very bizarre thing to do since pov does linear
calculations on light so by definition it has a gamma of 1, it's very
counter intuitive but it works!
Anyway I couldn't resist the urge to have a go at a similar scene myself, so
here's a picture and the source is in p.b.s-f. Most importantly note that
the reflection on the water is very subtle, without the ripples you'd hardly
see the water surface at all.
Tek
http://evilsuperbrain.com
Download 'rock mat test.jpg' (62 KB)
Preview of image 'rock mat test.jpg'
