POV-Ray : Newsgroups : povray.binaries.images : Planet Earth : Re: Planet Earth Server Time
26 Oct 2026 18:36:14 EDT (-0400)
  Re: Planet Earth
Date: 29 May 2006 14:22:58
Message: <447b3c02@news.povray.org>
Hmm, ran into difficulties with density file 8which is required for
interpolate). Let me post here the source code for the scene, maybe you can
show me how it should be.
Thanks,
Sven
"Zeger Knaepen" <zeg### [at] povplacecom> schrieb im Newsbeitrag
news:447b354d$1@news.povray.org...
as for comments: you should use interpolate with your image_map
#include "textures.inc"
#include "shapes.inc"
#include "metals.inc"
#include "glass.inc"
#include "woods.inc"
#declare Earth = texture { pigment { image_map { jpeg "E:\Scripts\Eigene
Bilder\Povray Textures\Sphere_Earth_01.jpg" map_type 1 } rotate < 0.0, 0.0,
0.0 > } finish { ambient 0.0 } }
#declare EarthLights = texture { pigment { image_map { png
"E:\Scripts\Eigene Bilder\Povray Textures\Sphere_Earth_Lights_01.png"
map_type 1 } rotate < 0.0, 0.0, 0.0 > } finish { ambient 0.25 } }
#declare EarthClouds = texture { pigment { image_map { png
"E:\Scripts\Eigene Bilder\Povray Textures\Sphere_Earth_Clouds_03.png"
map_type 1 } rotate < 0.0, 0.0, 0.0 > } finish { ambient 0.0 } }
global_settings
 assumed_gamma 2.0
 radiosity {  }  //
camera
 location < 000.0, 0.0, -300.0 >
 look_at < 000.0, 0.0, 0.0 >
light_source
 < 1000.0, 0.0, 250.0 >
 color White *3
#macro StarSubPigment(StarSize, StarFrequency)
 crackle
 form < 1.0, 0.0, 0.0 >
 #local Cutoff=StarSize*StarFrequency;
 color_map
  [ Cutoff rgb 1.0 ]
  [ Cutoff rgb 0.0 ]
 scale 1/StarFrequency
// minsize, maxsize = size range of stars (some stars will always be smaller
due to nature of crackle pattern)
// starfrequency = how many stars
// variationfrequency = how quickly their size changes
#macro StarPigment(MinSize, MaxSize, StarFrequency, VariationFrequency)
 #local NumSizeSteps=8;
 pigment
  pigment_pattern
   bozo
   color_map
    [ 0.0 rgb 0.75 ]
    [ 1.0 rgb 1.00 ]
   scale 1/VariationFrequency
  pigment_map
   #local StepNum=0;
   #while (StepNum<NumSizeSteps)
    #local SizeAmnt=(StepNum+.5)/NumSizeSteps;
    #local PreSize=MinSize+(StepNum/NumSizeSteps)*(MaxSize-MinSize);
    #local PostSize=MinSize+((StepNum+1)/NumSizeSteps)*(MaxSize-MinSize);
    [ SizeAmnt StarSubPigment(PreSize,StarFrequency) ]
    [ SizeAmnt StarSubPigment(PostSize,StarFrequency) ]
    #local StepNum=StepNum+1;
sky_sphere
 StarPigment
  0.000002,  // min star size
  0.000008,  // max star size
  10000,     // star density (higher = more)
  5          // variation frequency (higher = star size changes more over
nearby parts of the sky)
#declare Earth_Surface=sphere
 0.0, 1.0
 texture { Earth }
 texture { EarthLights }
 normal
//  density_file df3 "Sphere_Earth_Bumps_01.df3"
//  interpolate 1
  bump_map
   jpeg "Sphere_Earth_Bumps_01.jpg"
   map_type 1
#declare Earth_Clouds=sphere
 0.0, 1.0005
 texture { EarthClouds }
 normal
//  interpolate 1
  bump_map
   jpeg "Sphere_Earth_Clouds_Bumps_03.jpg"
   map_type 1
#declare Earth_Atmosphere=sphere
 < 0.0, 0.0, 0.0 > 1.0
 pigment
  color rgbt < 0.3, 0.3, 1.0, 1.0 >
 hollow
 interior
  media
   intervals 10
   scattering
    2,
    rgb < 0.3, 0.3, 1.0 >
    extinction 1.0
   }   // 0.75
   density
    spherical
    color_map
     [ 0.000 rgb < 0.0, 0.0, 0.0 > ]
     [ 1.000 rgb < 0.1, 0.1, 0.5 > ]
   samples 1, 10
   confidence 0.9999
   variance 1/1000
   ratio 0.9
 finish { ambient 0.0 diffuse 0.9/**/ }
 scale 1.0075
#declare Earth=union
 object { Earth_Surface }      //
 object { Earth_Clouds }       //
 object { Earth_Atmosphere }   //
 scale 100.0
object { Earth }
