POV-Ray : Newsgroups : povray.binaries.images : bottle [YAHDRI] : Re: bottle [YAHDRI] Server Time
12 Nov 2026 17:24:23 EST (-0500)
  Re: bottle [YAHDRI]
Date: 31 Jul 2004 12:13:40
Message: <410bc534$1@news.povray.org>
Jeremy M. Praay nous apporta ses lumieres ainsi en ce 29/07/2004 18:25... :
>I tried photons, but when used in combination with a high max_trace_level
>(I'm think), they took FOREVER to render and sucked up a ton of memory, so I
>killed the idea.  If anyone has any tips in that department, I would greatly
>appreciate it.
Reduce max_trace_level as much as you can, then add your photons.
>I used a lathe object (cubic_spline) for the bottle.  It actually has a
>hollow interior, and the glass actually has thickness.  I don't know if
>that's the approach that most people take.
Maybe not the way that "most" peoples use, but the way to do it if you
want a realistic bottle. Doing otherwize make the bottle look like a
buble...
>  Anyway, even with
>max_trace_level set to 256 (the max), POV still reports that it traced
>256/256.
It's caused by total internal reflections doing circles around the bottle.
>  Is there something I did wrong, or is that just the way it works?
>For this image, it was set to 50.
