POV-Ray : Newsgroups : povray.binaries.images : Odd blur effect: squared spheres : Re: Odd blur effect: squared spheres Server Time
25 Mar 2026 23:42:21 EDT (-0400)
Date: 27 Aug 2002 15:24:54
Message: <3d6bd206$1@news.povray.org>
> > Shouldn't it be a circular area for realism?
> correct ...
I don't think that's correct actually...
> either that or you can start modelling complex shapes for a
> probability model. Meaning, you support a greyscale bitmap
> where black says "no here won't get a ray shooten from" and
> white means that from here will get a ray shooten with the
> highest probability.
> This would allow you to form flare shapes as they sometimes
> appear in photography; think of hexagonal or triangular ones.
> The problem would be, that it will even slower to determine
> the point.
True, but I would be happy with the possibility to choose between a circular
area and an area in the shape of a regular polygon.
I was trying to do focalblur by averaging different renders earlier this day.  I
came up with the following formula to scatter points inside a regular polygon:
  #declare Seed=seed(whatever);
  #declare angles=<insert number of angles here>;
  #declare Rot=360*rand(Seed);
  #declare X=pow(rand(Seed),.5);
  #declare Rot2=Rot/(360/angles);
  #declare fraqrot=Rot2-int(Rot2);
  #declare fraqrot2=abs(fraqrot-.5);
  #declare fraqrot3=pow(fraqrot2*2,.5);
  #declare Location=vrotate(x*X*(.8+.2*fraqrot3),Rot*z);
This produces a random point within a regular polygon inside a circle with
radius 1 (I think, could be that it's a bit outside that circle...) (more or
less, it's not a perfect polygon, and it needs more than 3 angles to look like a
polygon)
cu!
