POV-Ray : Newsgroups : povray.binaries.images : Let's make a forest : Re: Let's make a forest Server Time
21 Oct 2026 04:40:45 EDT (-0400)
Date: 17 Apr 1999 22:46:29
Message: <37193853.765EEF17@bahnhof.se>
Sorry to disagree again, but no, It can be done with a good uniform scaling of
the object so it keeps the curent scale of the objects. This should be quite
easy to implement.
something like this is in my mind..
translate -1*MinExtent
//that should center the object with one corner on <0,0,0>
Then there should be a scaling, something like:
scale 1/(MaxExtent-MinExtent)
in my mind the tree will keep it's scale in sizes, but be downscaled to fit...
perhaps I'm to tired to think straight, but then, what good is straight?
(Go chaos, go)
Gilles Tran wrote:
> Hmm. It could be useful in some cases, and a little cumbersome in others.
> Personnally I prefer having the trees not scaled and adjust the size using the
> dummy bounding box: for instance, if you generate several trees just but changing
> the random seed or the recursion level, you'll get trees of different sizes but
> with a similar scale. If the trees were post-scaled, you'd get even-sized trees but
> with actually different scales, so you would have to make trial-and-error scaling
> to have trees consistent with each other. There's also the fact that the trees
> don't exactly fit in a box. Some of them crawl, some shoot up, so there's no ideal
> unit-size bounding box. In fact people who provide really good 3D trees also
> provide the "real life" bounding box : see http://iris8.cirad.fr/index.htm and look
> at the plant catalogue.
> Now if you really want it, I can add it as an option.
> Gilles
> Spider wrote:
> > hmm, this probably doesn't fit in this group, but should be in a separate mail
> > to Giles. but then, hehe.
> > To ease it all up with object placing and scalability, can you make the trees
> > all downscaled(upscaled) to a bounding_box{<0,0,0>,<10,10,10>}. This would help
> > a lot, and would also remove the need to recalculate the tree to fit.
> > I have an automated rescaler #macro here somewhere, if you are interested...
> > Lewis wrote:
> > > I had another weird idea:
> > > Let's compile a library of trees, made with Giles macro. Using a macro
> > > to generate random trees, each one starts it with a different seed and
> > > sends in the results (the include files). It could be very useful. Maybe
> > > someone will need a couple of trees sometime. Instead of parsing, say,
> > > 100ds of them, he will just download them.
> > > Anyone with me? If there will be enough enthusiasm I'll set up a web
> > > site or somethin'.
> > //Spider
> >         [ spi### [at] bahnhofse ]-[ http://www.bahnhof.se/~spider/ ]
> > What I can do and what I could do, I just don't know anymore
> >                 "Marian"
> >         By: "Sisters Of Mercy"
//Spider
                "Marian"
