POV-Ray : Newsgroups : povray.binaries.images : Bug with Blobs ? : Re: Bug with Blobs ? Server Time
21 Oct 2026 08:57:35 EDT (-0400)
Date: 14 Mar 1999 06:44:13
Message: <36EBA0C6.654AEFE0@aol.com>
That does look peculiar. Did you try using the 'sturm' keyword in the
blob statement though?
But I haven't seen such a incomplete set of blobs before. In case you
haven't seen many of the recent animations using blobs, they don't have
any of this problem apparently. Nor have I ever seen them get as bad as
this. Trying to think from memory whether there was any fixes to blob{}
since 3.1a and only a texture placement fix comes to mind (I think).
Could that be it?
Ph Gibone wrote:
> Hi There
> If you look to the attached images there are many notches (look at the red
> ovals) in the object which is a very simple blob made of spheres.
> If I rotate the object, the notches change place and size, so I'm quite sure
> it is a bug in POVRay (version 3.1a).
> Any one knows about this ?
> Philippe
 mailto:inv### [at] aolcom?PoV
