Does any body do 3d animation? The red\blue anaglyph kind.
I wrote a windows program to combine the two 2d images into the 3d anaglyph.
Really rewrote my old 'RB_3d' program at <http://leroyw.byethost15.com/>
by adding a batch run that can do animation files.
When I was about to upgrade my web site, I thought about upgrading the POV files
that comes with 'RB_3d'. While going through them I need to know just what did
I want to do.
If I had POV make both left and right 2d images one after the other using
animation in the ini file, I have to either rewrite the batch to skip files or
use POV shells to rename the 2d image files. So I started on how POV shells
work.
I wrote a shell program to do renaming. But I wasn't satisfied, I still had a
lot of disk space being use. A 800 frame animation would have 2400 images on
disk.
I could get rid of 2/3 of those files, if I use POV to make the 3d image from
the two 2d image already on the disk then delete the 2d images.
Now I have TWO systems to make animated Anaglyphs.
system 1 : POV makes all the left images for an animation
POV makes all the Right images for an animation
use RB_3d to combine images
make animation using your favorite tools
system 2 : using animation in POV ini with my shell program
POV makes the 3d images for an animation
Now I really have a choice do I?
1:put both on my web site
2:put system 1 only on my web site
3:put system 2 only on my web site
4: don't put upgrade
So thanks for any feed bake!
Have fun!
