*****P FRAME SUMMARY*****
I Blocks: 796 (136284 bits) ( 171 bpb)
P Blocks: 2631 (226959 bits) ( 86 bpb)
Skipped: 473
Frames: 13 (364720 bits) (28055 bpf) (18.7% of total)
Compression: 65:1
Seconds: 0 ( 0 spf) ( 0 bps)
*****B FRAME SUMMARY*****
I Blocks: 154 ( 15568 bits) ( 101 bpb)
B Blocks: 9129 (217553 bits) ( 23 bpb)
Skipped: 5717
Frames: 50 (238792 bits) ( 4775 bpf) (12.3% of total)
Compression: 385:1
Seconds: 6 ( 0 spf) ( 15360000 bps)
Total Compression: 83:1
Total Frames Per Second: 9.7777778
Total Output Bit Rate (30 fps): 663207 bits/sec
238k for 90 frames
acknowledgement:
ENC11DOS.ZIP
All the changes applied to the original code of "mpeg_encode"
by the Berkeley Research Group to produce the DOS-port "mpeg_enc.exe"
are copyrighted by PHADE Software. PHADE Software accepts all other
trademarks and copyrights.
Permission to use, copy, modify, and distribute this software and
its documentation for any purpose and without fee is hereby granted,
provided that the archive remains complete, that this author notice
will appear in all copies and as long as you don't try to make money
off it, or pretend that you wrote it, that the use of the software
is not against the GNU-licence or touches any other rights by the
original authors of this software.
Berlin, 27.09.1993 Frank Gadegast
PHADE SOFTWARE Leibnizstr. 30, 10625 Berlin, GERMANY
Inh. Frank Gadegast Fon/Fax: +49 30 3128103
phade [ @ ] cs.tu-berlin.de pha### [at] contrib de
Download 'trnsport.mpg' (238 KB)
