the exercise was to take the ballroll anim from helpfile and roll it in a
circle
to test my ability to use pov.
Download 'ballroll.gif' (420 KB)
Preview of image 'ballroll.gif'
num rolls = 3.7239
I spaced-out on the angle for the numrolls. 90-30 = 60
aas-sin(pi/2,deg2rad(60),4.3) = 3.7239
Download 'ballroll2.gif' (419 KB)
Preview of image 'ballroll2.gif'
rolls = 4.0;
vlength = 4.61888
#declare A_point = vrotate(vaxis_rotate(z,A,-30),360*clock*y)*4.61888;
so there is an even num rolls per loop
Download 'ballroll3.gif' (443 KB)
Preview of image 'ballroll3.gif'
Couldn't resist one more
texture really made the file size jump
here's half of it
Download 'ballroll_05.gif' (616 KB)
Preview of image 'ballroll_05.gif'
animation looks like this now but is 9 meg gif.
is there some mpeg makers out there - from still frames?
Download 'ballroll_0250.png' (208 KB)
Preview of image 'ballroll_0250.png'
Lookin' good. I use TMPGEnc (http://www.tmpgenc.net).
still using gif
but got it small enough to post, no bg.
Download 'down_the_drain_smb.gif' (480 KB)
Preview of image 'down_the_drain_smb.gif'
alphaQuad nous apporta ses lumieres en ce 2007/10/05 16:26:
> still using gif
At that size, you could remove the texture on that torus, it will make the file
somewaht smaler.
The other day I came home and a guy was jogging, naked. I asked "Why?" He
said "Because you came home early."
Rodney Dangerfield
hey Alain.
Debug_Message this:
clamp(0.65 - 0.75,0.0,0.25) = 0.15
and should be 0.0
by my macro logic:
#macro _clamp(nn,n,m)
#local result = nn;
#if (nn < n) #local result = n;
#if (nn > m) #local result = m;
result
took awhile of messin with stuff that didnt need messin with cause I assumed
clamp() would work.
5 bits per pixel setting on file save was the answer for a little larger
image. The texture was useless and ugly
Download 'down_the_drain_01.gif' (590 KB)
Preview of image 'down_the_drain_01.gif'
