Chambers <ben### [at] pacificwebguy com> wrote:
> Meothuru wrote:
> > simply an animated robot
> Can you 'program' it to reach arbitrary locations? If so, I'd love to
> do a chess game run by these arms :)
> ...Chambers
I've modified the scene a little bit.
So now it ist possible to control the robot movements
by an external control datafile(named: control.dat)
This is a simple ASCII-textfile
This allows you to render "free programable" robot
animations - based on this scene.
The robot control is IMO not very difficult, but if you want to
create animations with complexe movements, it gets
labour-intensive. Because the parts of the movement
must be rendered "step-by-step"
The description of the control data-file structure, I wrote
as a comment-text directly in the controldata-file "control.dat"
This text can be deleted, modified etc.......the scene reads
only the first two lines of the "control.dat".
A restriction of this scene is, that the movement does not know
a "smooth start/stop-phase" If you want to have this, you must
code it yourself.
Download 'robot2_archiv.zip' (32 KB)
