POV-Ray : Newsgroups : povray.binaries.animations : Liquid animation 20 Server Time
1 May 2026 09:10:13 EDT (-0400)
  Liquid animation 20 (Message 1 to 6 of 6)
Subject: Liquid animation 20
Date: 22 Apr 2006 07:40:01
Message: <web.444a150515060be7a6ae6c3e0@news.povray.org>
Hello,
I post a new water surface simulation. It's a water flow that turn a wooden
wheel.
The simulation was very long (around 72 hours). The rendering was quick
(around 10 hours) because I don't use photons or radiosity.
The video is MPEG1 encoded.
Any comment is wellcome.
Fidos.
Download 'wheel.mpg' (673 KB)
Subject: Re: Liquid animation 20
Date: 22 Apr 2006 14:58:54
Message: <444a7cee@news.povray.org>
> a wooden wheel.
> quick (around 10 hours) because I don't use photons or radiosity.
The "water" looks way too viscous, for the diameter of that pipe I would
expect the flow rate to be much higher.  Just my gut feeling, it looks more
like oil.
Date: 22 Apr 2006 16:55:01
Message: <web.444a974a5a3e83a9a8399d8d0@news.povray.org>
it's very good.
I looked at it a long time, and I can't see anything that looks out of
order. I don't think the water is too viscous, it depends a bit on what the
scale is. If the tube diameter is small, then it all looks ok to me. maybe
it looks a little slow. if I play it at 1.25 of normal speed, it looks more
realistic, but it makes it harder to see what's going on then.
It's not easy to make complex fluid simulation look anywhere near realistic.
I'm very impressed.
Date: 25 Apr 2006 13:55:01
Message: <web.444e61315a3e83a97788fad10@news.povray.org>
> like oil.
I think the viscosity is correct. I think your feeling is more linked to the
fact that there is no splashes or bubbles in the water.
> it's very good.
> I'm very impressed.
Thank you for your positive reply.
Fidos
Date: 26 Apr 2006 12:04:28
Message: <444f9a0c@news.povray.org>
>> would expect the flow rate to be much higher.  Just my gut
>> feeling, it looks more like oil.
> linked to the fact that there is no splashes or bubbles in the
> water.
My feeling was more to do with the water coming out the end of the pipe, it
seems to be flowing too slowly to keep the whole diameter filled (if you
know what I mean).  For the flow rate that is visible I would expect the
water to be running along the bottom edge of the pipe, not taking up the
whole pipe.
But as already commented, maybe this is because it is not clear what size
the pipe is, if it is a small pipe (eg a drinking straw) then it looks about
right.
Still, excellent work!
Date: 26 May 2007 12:41:55
Message: <46586353$1@news.povray.org>
"scott" <spa### [at] spamcom> wrote in message news:444f9a0c@news.povray.org...
> > water.
it
> whole pipe.
Problem with flow rate is probably due to the apparent length of the pipe.
To me, it looks like water is being "generated" at the bottom of the pipe,
instead of at the top, where we would expect the reservoir to be. The
kinetic energy of it leaving the pipe doesn't correlate with the length of
the pipe we are seeing.
