POV-Ray : Newsgroups : povray.binaries.animations : T_Stone28 289K Server Time
3 Mar 2026 02:59:10 EST (-0500)
  T_Stone28 289K (Message 1 to 8 of 8)
Subject: T_Stone28 289K
Date: 28 Feb 2006 08:15:01
Message: <web.44044c1b2e8a8a98b1b469160@news.povray.org>
A test animation of t_stone2
Download 't_stone2801.mpg' (289 KB)
Subject: Re: T_Stone28 289K
Date: 28 Feb 2006 17:27:37
Message: <4404ce59$1@news.povray.org>
Nothing appears to happen.  Should I download again?
John
Date: 1 Mar 2006 03:45:00
Message: <web.44055e07167f37d7b1b469160@news.povray.org>
> Regards,
> John
povray.animations, Flickering flick help!
If you look closely you will be able to see some slight flickering in the
cube.
Date: 1 Mar 2006 06:34:26
Message: <440586c2$1@news.povray.org>
I find this a bit strange.
There's absolutely no motion in this scene (I hope)
but there is this flicker. It must somehow be related
to the video compression method used.
Date: 1 Mar 2006 07:05:00
Message: <web.44058d9b167f37d7b1b469160@news.povray.org>
Correct, that is what it is supposed to show.
It was a test for the thread, in povray.animations, Flickering flick help!
kind.
Date: 1 Mar 2006 08:45:13
Message: <4405a569$1@news.povray.org>
Stephen wrote:
> kind.
Well there is movement though no intended,
so I think it fits here.
It was also educational at least for me as well
as the thread in p.animations.
Sebastian
Date: 1 Mar 2006 10:35:00
Message: <web.4405bdf9167f37d7b1b469160@news.povray.org>
As it was for me, too.
Date: 2 Mar 2006 03:00:36
Message: <VNr2sDAWUqBEFwB6@econym.demon.co.uk>
You can check whether the effect is occurring in POV-Ray or in the
animation compression routines by taking two raw frames, as output by
POV-Ray, into a suitable image processing application, calculating the
difference between the images and enhancing the contrast.
When I try that with a cube of T_Stone28 with "-J" in the command line
the frames are identical. The difference is perfectly black. If that's
the case for you, then the effect is nothing to do with POV-Ray.
Mike Williams
Gentleman of Leisure
