POV-Ray : Newsgroups : povray.binaries.animations : snow animations Server Time
1 May 2026 10:48:00 EDT (-0400)
  snow animations (Message 1 to 6 of 6)
Subject: snow animations
Date: 28 Dec 2005 19:25:01
Message: <web.43b32c06f15ea5a54272d270@news.povray.org>
Who help.I have this source code.
#declare PtA=<-30,0,-30>;
#declare PtB=<30,35,15>;
#declare nasio=seed(12345);
#declare ile=1000;
#declare licz=1;
#declare platek=sphere
  <0,0,0>,
  .1 pigment
  { color White }
#while
     (licz <ile)
        #declare los=VRand_In_Box(PtA, PtB, nasio);
        object { platek translate los }
        #declare licz=licz+1;
I want snowing animations.What I must write to this code and where becasue
I'm newbie in Povray.
HELP ME.PLEASE
Subject: Re: snow animations
Date: 29 Dec 2005 05:33:55
Message: <43b3bb93@news.povray.org>
"r20adek" <rra### [at] o2pl> wrote in message
news:web.43b32c06f15ea5a54272d270@news.povray.org...
> ... snip ...
> HELP ME.PLEASE
Hi Radek,
To animate your snowflakes you need to modify the amount you move each one
based upon the 'clock' variable. The following source adds a vector to the
position of each flake to produce a very simple animation. It checks to make
sure the flake hasn't dropped out of the bottom of the box and, if it has,
it moves it back to the top of the box, positioning it so that it will
produce a seamless animation cycle when rendered with the command line
settings of   '+kfi1 +kff30 +kc'.
A couple of notes on protocol: I think it would have been better to post
this question on the 'povray.animations' newsgroup as
'povray.binaries.animations' is more for example animation files and stuff.
CAPITALISATION is sort of like shouting and is more commonly used on
newsgroups where questions don't get answered.
light_source { < -150, 80  ,-8> color rgb 1}
camera {location <0,20,-20> look_at <0,20,0>}
#include "rand.inc"
#declare FallVector = <-0.1,-1,-0.1>;
#declare ile=1000;
#declare licz=1;
  <0,0,0>,
  .1 pigment
  { color White }
#while
     (licz <ile)
        #declare los = los+FallVector*clock*35;
        #if (los.y<=0) #declare los = los-FallVector*35; #end
Chris B.
Date: 29 Dec 2005 18:00:01
Message: <web.43b4698b37e0571554272d270@news.povray.org>
Can you tell me what I must do when snowflakes is animated??Because I'm vey
newbie and I don't now what I must do??????
#include "textures.inc"
#include "rand.inc"
plane
        <0,1,0>,10000 hollow
      texture
              pigment
              {color rgb<0.2,0.2,0.3>}
              finish
              {ambient 1  diffuse 0}
plane
        <0,1,0>,1 hollow  //
      texture
            pigment
                   bozo
                   turbulence 0.65
                        octaves 6  omega 0.7 lambda 2
                        color_map { [0.0 color rgb <0.95, 0.95, 0.95>]
                                    [0.1 color rgb <0.85, 0.85, 0.85>]
                                    [0.5 color rgbt <1, 1, 1, 1> ]
                                    [1.0 color rgbt <1, 1, 1, 1> ]   }
                        rotate<10,20,0>
                        scale <0.3, 0.4, 0.2>*3 }
              finish
              ambient 1 diffuse 0}}
      scale 1000}
// fog at the horizon
fog
   distance 300000 color White}
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
  fog {
        fog_type 2 // tu określamy typ mgły
        fog_alt 1 // tu okreslamy jak szybko mgla ma malec
        fog_offset 0
        distance 2
        color <0.6,0.5,0.5>
light_source
           <-400,2500,-1000> colour White}
plane
       y,0 pigment
                 {colour White}
                 finish
                 {phong 1}
camera
      location <10,10,-50>
      look_at <0,22,0>
light_source
               <0,10,-6>
               colour White
        sphere
                 <-30,8,20>
                 9 pigment
                         {colour White}
                          finish
                          {reflection 0 phong 0}
 sphere
           <-27,6,13>
           1.5 pigment
                      {colour Yellow}
                      finish
 sphere
             <-27,10,13>
             1.5 pigment
                        {colour Yellow}
                        finish
 sphere
           <-27.4,14.5,14>
           1.2 pigment
           {colour Yellow}
           finish
        sphere
                   <-28,21.9,15>
                   7.8 pigment
                   {colour White}
                   finish
  sphere
            <-24.7,16,8.4>
            1 pigment
            {colour Yellow}
            finish
  sphere
            <-24.5,20,8>
            1 pigment
            {colour Yellow}
            finish
  sphere
             <-20.7,22.5,1>
             0.9 pigment
             {colour Yellow}
             finish
        sphere
                   <-26.3,33,9>
                   6 pigment
                   {colour White}
                   finish
     union
  cone
          <-20.3,27,0>
          1
          <-20,22,0>
          0
  pigment
         {colour Red}
sphere
          <-25,32,2>
          0.9 pigment
          {colour Blue}
          finish
sphere
          <-20,31.5,2>
          0.9 pigment
          {colour Blue}
          finish
cylinder
             <-24,45,2>   <-24,35,5>
             5 texture
               pigment
               {Black}
#declare ile=1000;
#declare licz=1;
  <0,0,0>,
  .1 pigment
  { color White }
#while
     (licz <ile)
Date: 29 Dec 2005 19:07:26
Message: <43b47a3e$1@news.povray.org>
news:web.43b4698b37e0571554272d270@news.povray.org...
> vey
The source you have is fine for animation.
If you render your source with the command line options "+kfi1 +kff30 +kc"
(Initial_Frame=1, Final_Frame=30 and Cyclic Animation) you'll get 30 images
numbered 1 to 30. If you're on Windows you can get a preview of your
animation by putting the images in a separate directory and using the
Windows Picture and Fax Viewer to open the first image, then holding the
mouse button down on the 'Next Image' button cycles through the images.
To build these images into a proper animation you will need to use a
separate piece of software to take the individual frames and generate an
animation file. You need to decide upon a suitable format for your animated
sequence, for example mpeg, moov, avi or animated gif.
There are many different tools you can use, some of them free and available
for download over the Internet.
The choice of format depends on how you want to use the animated file. If
you want to embed it on a web page then animated gif is the simplest and
most widely compatible approach and you can build animated gif's with the
Gif Constructor Set (do a Google search for gifcon32.exe).
You'll need to read up on how to use your tool of choice to generate
whichever format you choose.
Chris B.
Date: 29 Dec 2005 19:11:10
Message: <43b47b1e@news.povray.org>
"Chris B" <c_b### [at] btconnectcomnospam> wrote in message
news:43b47a3e$1@news.povray.org...
> If you're on Windows you can get a preview of your animation by putting
> the images in a separate directory and using the Windows Picture and Fax
> Viewer to open the first image, then holding the mouse button down on the
Correction. - Holding the Page Down button on your keyboard cycles through
the images.
Chris B.
Date: 5 Jan 2006 05:30:00
Message: <web.43bcf4cb37e05715a8399d8d0@news.povray.org>
> the images.
or even better: http://www.irfanview.com/
open the first file, and use the mouse wheel to scroll through the
animation.
Irfanview also has a slide show option that can be set to 25Hz (0.04
sec/image)
It can also be used to do batch conversion between different image formats,
this is helpful if you rendered your frames as png, but your animation
software needs jpg's or bmp's. (to bad there isn't a Linux version :-)
