Yet another Rollin anim, this is going somewhere, one of those unnecessarily
complicated machines that turns the lights out on a V8 Supercar race
starting the battle. The balls will cause the letters Panorama Productions
to appear along the way. This anim, the 5 balls are loose though there are
no particle interactions, so the balls roll through each other.
James
Download 'coaster6lq.mpg' (431 KB)
Had to vectorise the vectors for this one, the turns bank properly and the
rails never leave their supports. Here is the code for the track building.
#while (section < sections-1)
#declare bear1 = tpoints1[section][0];
#declare bear2 = tpoints1[section+1][0];
#declare azim1 = tpoints1[section][1];
#declare azim2 = tpoints1[section+1][1];
#declare roll1 = tpoints1[section][2];
#declare roll2 = tpoints1[section+1][2];
#declare xpos1 = tpoints1[section][3];
#declare xpos2 = tpoints1[section+1][3];
#declare ypos1 = tpoints1[section][4];
#declare ypos2 = tpoints1[section+1][4];
#declare zpos1 = tpoints1[section][5];
#declare zpos2 = tpoints1[section+1][5];
// Components
#declare xcomp1 = abs(w1 * sind(roll1) * sind(azim1));
#declare xcomp2 = abs(w1 * sind(roll2) * sind(azim2));
#declare ycomp1 = w1 * sind(roll1) * cosd(azim1);
#declare ycomp2 = w1 * sind(roll2) * cosd(azim2);
#declare zcomp1 = w1 * cosd(roll1);
#declare zcomp2 = w1 * cosd(roll2);
// Left Rail
#declare lrx1 = xpos1 + xcomp1 * cosd(bear1) - zcomp1 * sind(bear1);
#declare lrx2 = xpos2 + xcomp2 * cosd(bear2) - zcomp2 * sind(bear2);
#declare lry1 = ypos1 - ycomp1;
#declare lry2 = ypos2 - ycomp2;
#declare lrz1 = zpos1 + xcomp1 * sind(bear1) + zcomp1 * cosd(bear1);
#declare lrz2 = zpos2 + xcomp2 * sind(bear2) + zcomp2 * cosd(bear2);
// Right Rail
#declare rrx1 = xpos1 - xcomp1 * cosd(bear1) + zcomp1 * sind(bear1);
#declare rrx2 = xpos2 - xcomp2 * cosd(bear2) + zcomp2 * sind(bear2);
#declare rry1 = ypos1 + ycomp1;
#declare rry2 = ypos2 + ycomp2;
#declare rrz1 = zpos1 - xcomp1 * sind(bear1) - zcomp1 * cosd(bear1);
#declare rrz2 = zpos2 - xcomp2 * sind(bear2) - zcomp2 * cosd(bear2);
#cylinder {<lrx1,lry1,lrz1> <lrx2,lry2,lrz2> 0.025 pigment {rgb <1,0,0>}
#cylinder {<rrx1,rry1,rrz1> <rrx2,rry2,rrz2> 0.025 pigment {rgb <0,0,1>}
#sphere {<lrx1,lry1,lrz1> 0.025 pigment {rgb <1,0,0>} }
#sphere {<rrx1,rry1,rrz1> 0.025 pigment {rgb <0,0,1>} }
#declare section = section + 1;
Download 'coaster9lq.mpg' (323 KB)
The problem here (in my *always* humble) opinion is anticipation. When I
ride a roller coaster and I see that the track swings off to the left I
naturally turn my head left... before I hit the corner. Your animation
is awesome, but you need to add a tiny bit of camera angle to match the
viewer's desire to look around the next corner.
> // Components
> // Left Rail
> // Right Rail
> #end
