POV-Ray : Newsgroups : povray.binaries.animations : Liquid animation 9 Server Time
3 Mar 2026 04:51:13 EST (-0500)
  Liquid animation 9 (Message 1 to 8 of 8)
Subject: Liquid animation 9
Date: 16 Jun 2005 14:30:02
Message: <web.42b1c4a9449e07c368cd871b0@news.povray.org>
Helo,
I post a new liquid animation. This time, I played with a falling tank with
water inside.
The video is MPEG1 encoded.
Fidos
Download 'tank.mpg' (693 KB)
Subject: Re: Liquid animation 9
Date: 16 Jun 2005 15:14:16
Message: <42b1cf88$1@news.povray.org>
"fidos" <fid### [at] wanadoofr> wrote in message
news:web.42b1c4a9449e07c368cd871b0@news.povray.org...
> Helo,
> water inside.
Looks good, except for the part in the beginning, I'm not sure how to describe
it, where the water should "splash" down, but instead appears to "crawl back
down" :-/
That being said, I should also mention that this is about a million times better
than what I could do :)
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x)                 // ZK http://www.povplace.com
Date: 17 Jun 2005 08:21:23
Message: <42b2c043$1@news.povray.org>
> water inside.
Beautiful! I especially like the braking wave on the right as the tank
hits the table.
/ martin
Date: 17 Jun 2005 09:49:02
Message: <42b2d4ce$1@news.povray.org>
Beautiful simulation, but isn't there something wrong with the
refraction/ior of the water? The background looks the same when seen through
the water as it does when seen through the empty tank. I noticed the same
problem with the prior simulations, but it was not so visible, since they
were shown more from above.
Rune
rune|vision:  http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
Date: 17 Jun 2005 13:12:42
Message: <42b3048a@news.povray.org>
I hadn't checked this group for a while. I'm mesmerized by your fluid
animations. I had planned doing something similar some time ago, but due
to time constraints and the technical difficulty I never got too far.
I'm glad you're getting such awesome results. Congrats!
Fernando.
fidos wrote:
> Helo,
> water inside.
> Regards,
> Fidos
Date: 17 Jun 2005 15:31:15
Message: <42b32503$1@news.povray.org>
He must have the ior set though, or else the photons wouldn't work right.
Maybe the sides of the water are coincident with the tank so that refraction
isn't working right at that part?
IMO, the only improvement this needs is splashes so that it doesn't look
like gel.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 18 Jun 2005 03:30:00
Message: <web.42b3ccb7a3e41b6051cea61b0@news.povray.org>
Thank you all for your comments.
About the refraction mistake viewed by Rune. It's something I didn't noticed
(in fact, I checked with the fish tank I have at home...). The problem I
faced with PovRay is that I wasn't able to define with different properties
the air <-> water, air <-> glass and glass <-> water surface properties. I
made some CSG operation in order to have the ability to define glass <->
water property and I fixed it without ior (the idea was that there is no so
much difference between water and glass). I think it is the reason of the
strange effect.
Fidos
Date: 25 Jun 2005 19:52:34
Message: <42bdee42$1@news.povray.org>
> The problem I
properties
The best way to do this is to simply avoid coincident surfaces. You have two
options:
1. Slightly overlap glass and water. Rays will go through air -> glass ->
glass + water -> water, and in the process will use the air ior -> glass
ior -> water ior -> water ior.
2. Leave a tiny space between glass and water. Rays will go through air ->
glass -> air -> water, and in the process will use the air ior -> glass
ior -> air ior -> water ior. If the gap is small it won't be noticeable.
You may have already done one of these.
There is actually a significant difference; water's ior is 1.33 and glass is
1.5 according to the documentation. However, this doesn't explain why the
bookshelf looks the same through empty tank as it does through water.
 - Slime
