Hi Folks,
here is my first try to get familiar with animated media and density.
Hope i'll get some comments on it. (sniff) Movie is a XviD, because i
simply have no MPEG encoding software and XviD offers better compression
rate with lower quality loss than encoding an MPEG. What about of deleting
the file restriction to only MPEG-1 ? Stoneage is over ! :)) Not meant bad,
just a fact.
Bye, Shu.
Download 'desitytest.avi.dat' (648 KB)
Shurakai wrote:
> Hi Folks,
> just a fact.
> Bye, Shu.
Very nice looking. How are you modifying the density pattern to produce
this?
> this?
Hi Thomas,
Thanks for Your comment.
The density has been created by using the crackle pattern, like shown by
Chriss Huff and his density sphere. I think the file is contained in the
POV-Ray installation. Then You only need to add some turbulence and some
rotation. Thats it. I only added one media statement, using 4 or more will
look much better, but will increase the rendering time a lot. Thats not
usefull for an animation anymore.
Shu.
bad,
> just a fact.
It plays for me, but it's all jittered... the animation isn't smooth. When I
try to play it a second time without closing Windows Media Player, it
doesn't play at all.
You should consider encoding in a simpler format like MPEG (try tmpgenc)
since that will work for more people and increase your chances of getting
comments. =)
- Slime
[ http://www.slimeland.com/ ]
> comments. =)
Hmmm, strange. I encountered this bug with Windows Media Player too when i
used older Xvid codecs. The reason might be that You need the latest XviD
codec installed. Or simply use the Video LAN client, a small video player
which playes all kind of movies without any problems. It can be found here
http://www.videolan.org/vlc/
I think TMPGEnc isn't freeware. I can only use it for 14 days than i need to
register. Not really usefull for me. I'm restricted to use freeware like
VirtualDUB, because i want to post my animations on my homepage later. I'll
look if i can find some free encoding software, because You are right,
MPEG-1 is the most common format for videos.
Shu.
Free version of TMPGEnc can be used only for personal use or
noncommercial use such as presentation inside a company.
The MPEG-2 encoding capabilities expire after a trial-period, but MPEG-1
encoding is always functional.
