A julia fractal twisted around the x axis. A lot of spheres are put on the
surface using trace, and they are rotated using vaxis_rotate.
See my post on p.b.i. for more info.
http://gero.progressive.hu/twist.mpg
Gergely
Tek wrote:
>Wow that looks really cool! How long did it take to render?
Thanks. :) It was about 5 mins/frame on an 1.4 GHZ Athlon XP. 10.5 hours for
the whole thing.
>>The spheres add a realistic feel to the shape, because it's not a perfect shape>with a lumpy texture, it's actually made out of lots of seperate bits. It looks>almost like a soft sponge or something :)
At first I wanted a smooth surface, which I wasn't able to achieve, so this
came as a compromise.
Gergely
Fernando Gonzalez del Cueto wrote:
>Cooool... I like very much the red part of the texture.
Thanks. The red part is the inside of the Julia that you can see through the
cracks. The object is just a thin shell.
Gergely
