POV-Ray : Newsgroups : povray.binaries.animations : Rotating Disc segment - Disc020001.mpg (0/1) Server Time
1 May 2026 07:38:12 EDT (-0400)
  Rotating Disc segment - Disc020001.mpg (0/1) (Message 1 to 7 of 7)
Subject: Rotating Disc segment - Disc020001.mpg (0/1)
Date: 7 Sep 2006 17:09:59
Message: <m721g2h6hsoln0qb8lvmtpu4n7t0h8v78f@4ax.com>
For Kaeru Gaman
Kaeru  for what you wanted put a clock statement in the color_map
position
#declare Radial_Texture =
    radial
    color_map {
      [0 rgbft <0,0.7,0,0,0>]
      [0.074 rgbft <0,0.7,0,0,0>]
      [0.21 rgbft <0.889,0.889,0.889,0,0.889>]
      [0.242 rgbft <1,1,1,0,1>]
      [1 rgbft <1,1,1,0,1>]
Regards
Subject: Rotating Disc segment - Disc020001.mpg (1/1)
Date: 7 Sep 2006 17:10:17
Message: <6l21g2942inuvd7gd4og3cieb06bvh320p@4ax.com>
Download 'Disc020001.mpg' (373 KB)
Subject: Re: Rotating Disc segment - Disc020001.mpg (0/1)
Date: 17 Sep 2006 00:32:04
Message: <450ccfc4@news.povray.org>
Looks like the scan-line for a radar screen :)
"Stephen" <mcavoysATaolDOTcom@> wrote in message
news:m721g2h6hsoln0qb8lvmtpu4n7t0h8v78f@4ax.com...
> For Kaeru Gaman
> position
> texture {
>  pigment {
>    radial
>    color_map {
> Regards
> Stephen
Date: 17 Sep 2006 04:35:36
Message: <o52qg25th65upimi8og9sq92q7niatafgs@4ax.com>
On Sun, 17 Sep 2006 13:54:48 +0930, "Data Banks"
It does, doesn't it.
Regards
Date: 17 Sep 2006 06:12:17
Message: <450d1f81@news.povray.org>
news:o52qg25th65upimi8og9sq92q7niatafgs@4ax.com...
> Regards
> Stephen
I take it that's what you were aiming for, then? (I haven't had a chance to
read every post on the server yet)
Date: 17 Sep 2006 06:27:30
Message: <co8qg291uf0bt38r07qjo3qd1ee6mcgqn9@4ax.com>
On Sun, 17 Sep 2006 19:02:22 +0930, "Data Banks"
No I was illustrating an alternative method of showing a clock type
object. The original thread is in p.g (povray.general) called "Slice
in a Sphere". For a radar sweep you would need to narrow the opaque
section of the colour map and maybe change the colour to filter = 1.
As you would want the targets to be highlighted when the beam passes
over them.
There are an awful lot of posts going back a long time.
Regards
Date: 17 Sep 2006 07:11:14
Message: <450d2d52@news.povray.org>
news:co8qg291uf0bt38r07qjo3qd1ee6mcgqn9@4ax.com...
>>to
> over them.
Ah. Well, it would also make a good radar screen :) One of those "Hey, it
does something else, too!" results :)
Yep, even some way back when I first played with with beziers exported from
Moray many years ago. And then sadly ran out of time to do much more :(
> Regards
> Stephen
