POV-Ray : Newsgroups : povray.binaries.animations : Re: Media Test - Theatre06a001.mpg Server Time
1 May 2026 18:37:18 EDT (-0400)
  Re: Media Test - Theatre06a001.mpg (Message 1 to 2 of 2)
Subject: Re: Media Test - Theatre06a001.mpg
Date: 3 Jan 2004 07:11:33
Message: <Xns946586340AA94seed7@netplex.aussie.org>
in news:3m3cvv0lak15tgvcguu7eapdf86585dvjg@4ax.com Stephen McAvoy
wrote:
> This is low quality (no AA and low Media intervals (10)) settings. To
> reduce the time of render.
Did you use atmospheric media or contained media? The latter is faster.
> It shows the dullness I am experiencing
> with Media.
You could add a density pattern with some turbulence to make the
lightbeam more attractive. Also maybe put the spotlight closer to the
object, so the beam gets less parallel
> The spotlight is two spotlights one reacting to media to
> give the visible beam the other to give the spot on the ground. My
> initial idea was to control a spotlight but it developed into a long
> learning curve. I don't think I'd get a job as a spotlight
> operator:-} Any advice on media would be appreciated.
Below is a small scene.
- The fade_power/disytance is used to make the light brighter near the
spot (doesn't show much though :( )
- To animate the spot, add a clock to the PointAt variable.
- The cone is a bit too short, I didn't feel like figuring out the math.
- To vary the density, change the 'rgb 1' in scattering or play with the
color_map in the density block.
Your danceuse is great!
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 1, -6.0>
  look_at   <-1.0, 2, 0.0>
#declare Location=<-20,20,-5>;
#declare PointAt=<0,0,0>; //animate
light_source {
  Location
  rgb 1
  spotlight
  point_at PointAt
  radius 1
  falloff 3
  tightness 0
  fade_distance vlength(PointAt-Location)
  fade_power 2
cone {
  Location,0 PointAt,3.1  //a bit wider than falloff
  hollow
  pigment {rgbf 1}
  finish {ambient 0 diffuse 0}
  interior {
    media {
      intervals 1
      samples 1,1
      scattering {
        2,        // play with this
        rgb 1
        extinction 0.0
      method 3
      density {
        wood
        scale 2
        turbulence 0.5
        octaves 7
        lambda 0.5
        omega 0.5
        color_map{
          [0.0, rgb 0.1]
          [0.7, rgb 0.2]  //vary intesity of scattering
plane {
  y, 0
  pigment { color rgb <0.7,0.5,0.3> }
sphere {
  <0,0.6,0> 0.6
      rgb<1,0,0>
    finish{
      specular 0.6
Ingo
Date: 3 Jan 2004 10:00:00
Message: <b0mdvv8ah05dsumfrg9l7jkk7i901ukd0m@4ax.com>
I used contained media but it was a large-ish container. I am still
experimenting with media.
>> with Media.
I will add a density pattern with some turbulence later but first things first.
Since I like to make cyclic animations the smoky effect will need to be
carefully thought out. I have a lot of experience of looking at lighting in the
theatre. I initially had the spot much closer to the stage but the cone was too
obvious. Since I create my scenes using Moray I don't have the option of using
the point_at keyword and have to use the rotate <x,y,z>. This is not such a
great disadvantage because the meshes I use are displaced internally and as far
as PovRay is concerned they are static through out the animation. I used a
spline to control the rotation. I've just reread my initial statement and your
answer and I think there was some misunderstanding. When I said dullness I meant
lack of clarity or as if the objects were tarnished. I now think this is due to
a too high rgb value in the media.
In your scene you use a cone as a container, I tried that and because I needed
to use some secondary lighting, the container cone created a shadow (it looked
like a dark halo around the container cone). If I made it shadowless I got a
whiteout :-} so I used one spot reacting with media for the visible light
(strange phrase) and another to give a spot on the floor. Bob Hughes thought
that this problem could have been caused by the floor finish having a too low
diffuse value (Tested and true). So that is fixed.
Thank you, I think I have "cracked" using bvh files in Poser.
I appreciate your comments.
Regards
