POV-Ray : Newsgroups : povray.binaries.animations : Cylindrical pattern animation - how to get the circles overlap? Server Time
11 Oct 2026 17:12:20 EDT (-0400)
  Cylindrical pattern animation - how to get the circles overlap? (Message 1 to 2 of 2)
Subject: Cylindrical pattern animation - how to get the circles overlap?
Date: 12 Jun 2026 11:10:33
Message: <6a2c2169@news.povray.org>
Hi(gh)!
As a background for an animated text imploring a dear friend to buy a
new laptop, I want to have a white mesh2 screen with slowly growing
black polka dots, which finally overlap until no white is visible
anymore - but instead they just stop growing as they touch each other!
Is there a way to keep them growing anyway? Or do I have to use a
different pigment pattern?
Here is the code:
// begin code:
/* #declare loop=div(clock,200);
#switch(loop)
   #case(0) */
     #declare OuterColor=<1, 1, 1>;
     #declare InnerColor=<0, 0, 0>;
     #declare TranslateVector=<-0.005, -0.0035, 0>;
/*  #break
#end */
mesh2
   vertex_vectors
     4
     <-1, 0.5, 1>, <3, 0.5, 1>, <-1, -0.5, -1>, <3, -0.5, 1>
   face_indices
     2
     <0, 1, 2>, <1, 2, 3>
   texture
     pigment
       cylindrical
       rotate <90, 0, 0>
       translate <1, 1, 0>
       warp { repeat x*2 }
       warp { repeat y*2 }
       color_map
         [0 color rgb OuterColor]
         [1-clock/105 color rgb OuterColor]
         [1-clock/105 color rgb InnerColor]
         [1 color rgb InnerColor]
     finish { ambient 1 diffuse 0 }
     scale 0.05
     translate clock*TranslateVector
camera
   orthographic
   location <1, 0.15, -5>
   look_at <1, 0.15, 0>
   right <1000, 0, 0>
   up <0, 100, 0>
   angle 40
See you in Khyberspace!
Yadgar
Now playing: Apo 22 (Vangelis)
VBI BENE, IBI BACTRIA!
Subject: Re: Cylindrical pattern animation - how to get the circles overlap?
Date: 12 Jun 2026 16:30:00
Message: <web.6a2c6ba85624ce92fc5b0b10f712fc00@news.povray.org>
=?UTF-8?Q?J=C3=B6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
> Hi(gh)!
> Here is the code:
> // begin code:
> #switch(loop)
>    #case(0) */
> /*  #break
> #end */
> mesh2
>    vertex_vectors
>      4
>    face_indices
>      2
>    texture
>      pigment
>        cylindrical
>        rotate <90, 0, 0>
>        translate <1, 1, 0>
>        warp { repeat x*2 }
>        warp { repeat y*2 }
>        color_map
>      scale 0.05
> camera
>    orthographic
>    right <1000, 0, 0>
>    up <0, 100, 0>
>    angle 40
> Yadgar
When I first started to answer this. I thought 'scale the the pigment with the
clock'. Then I open the reply page and really looked at your code. I needed to
play with it to see what it's doing. And after many minutes this is what I came
up with
#declare A=1-clock;
plane{z,0 pigment{spherical color_map{[A,rgb 1] [A,rgb 0]}
        scale 1+clock*10
        translate <1, 1, 0>
        warp { repeat x*2 }
        warp { repeat y*2 }
     } finish{ambient 1}scale .05}
I guess you could just insert the 'scale 1+clock*10' into you code. But where
the fun in that?!:)
Have Fun!
