POV-Ray : Newsgroups : povray.binaries.animations : Playing with matrix transforms Server Time
7 Apr 2026 11:17:04 EDT (-0400)
  Playing with matrix transforms (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Playing with matrix transforms
Date: 21 Jan 2025 18:00:47
Message: <6790271f$1@news.povray.org>
On 1/21/25 15:30, Bald Eagle wrote:
> The isosurface looks like a strange, but interesting result to me, because
> you're getting distortion of the square instead of the simple rotation like you
> do in the checker.
> It sort of looks like a camera iris - something to be pursued, I think.
Yes, I added a f_hypot(x,y) multiplier to the two 'rotation/shear terms'
to create something more interesting than the square-frame rotating and
shrinking.
Attaching two more mp4s. The one with the _BW.mp4 suffix removes that
f_hypot() multiplier.
The one with the _SinCosHyp.mp4 suffix adds a sin() then cos() wrap of
the f_hypot() multipliers. Done with the thought it might be
interesting. :-)
Bill P.
Download 'matrixplayasiso_bw.mp4.dat' (37 KB) Download 'matrixplayasiso_sincoshyp.mp4.dat' (30 KB)
Date: 25 Jan 2025 09:50:00
Message: <web.6794f97628e99934e83955656e066e29@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> but I fully admit I'm just poking the matrix with a stick to
> see what happens. To some extent, I wonder about why it does what it
> does, but I care more about whether what it does might be useful.
That is also my usual method of playing with matrices, ha-- because I still have
a hard time understanding how they work and how to use them. I like your video
though; I need to experiment with your code example to see how I can break it!
[In Windows 10]  I thought I should mention something: In the newsgroups'
standard web portal that I use, the Firefox 'previews' of your .mp4 videos do
not play -- with the message "Video cannot be played because the file is
corrupt." (which is not the case!) As a comparison: Josh's .mp4 animation in his
recent post  "Go home, RSOCP, yer drunk" plays fine in the Firefox preview.
So I downloaded your video-- and it plays fine in *most* of my Windows 10 media
players: VLC Media Player, SM Player, and even my old VirtualDub2. But it does
not play in Windows' own Media Player (a black screen)-- and actually breaks
Irfanview (the app hangs and has to be terminated via Windows Task Manager.)
Irfanview will usually play just about any video that I throw at it, so its
behavior in this case is very weird.
In VLC Media Player, I took a look at your first posted video's encoding
statistics:
Codec: H264-MPEG-4 AVC (part 10) (avc1)
Video Resolution: 450 X 450
Buffer Dimensions: 464 X 482
Decoded Format: Planar 4:4:4 YUV
Color Primaries: ITU-R BT.709
I did some research (yet again!) about video encoding and codecs, because it is
all so complicated to remember. Your video's stats are fairly standard stuff
AFAIU-- except for the 4:4:4 chroma subsampling.  4:2:0 is the typical scheme
for h.264; I use that myself. Take a look at Wikipedia's "h.264" page,
particularly the subsection "Feature support in particular profiles". It appears
that 4:4:4 is only supported in a particular high-end 'flavor' of h.264; perhaps
that presents a problem for Firefox, and/or for Windows 10's built-in video
codecs.
Or maybe you encoded the videos using 10-bit colors rather than the more
standard 8-bit?
I also did a search for possible Firefox problems regarding playback of
h.264 .mp4 files, but found nothing that would be helpful-- except for this
possibility:
"Yes, Firefox can play 4:4:4 videos, but only if your hardware and system
settings support it; this is because the capability to play 4:4:4 video depends
on your graphics card and the video codec used, not solely on the browser
itself."
(By the way: I had the same video-playback problems with your December 2024
post,
 "New f_dnoise(), modified f_dturbulence(). yuqk R17"
but forgot to mention it at the time.)
Date: 25 Jan 2025 19:25:00
Message: <web.6795803c28e99934805081db89db30a9@news.povray.org>
For those of you that want to be able to do matrix calculations within POV-Ray,
I have made a library that can do some of that.
It can be found here:
https://github.com/t-o-k/POV-Ray-matrices
(NB: Some of the descriptions and examples are not finished yet.)
Below are some examples with this library that may be relevant to this thread.
Tor Olav
http://subcube.com
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.7;  // Should also work in version 3.8
global_settings { assumed_gamma 1.0 }
#include "matrices.inc"
#declare No_Change_Transform = transform { }
#declare Rotate_Transform = transform { rotate 60*x }
#declare Shear_Transform =
    transform {
        matrix <
            1, 1, 0,
            0, 1, 0,
            0, 0, 1,
            0, 0, 0
#declare Translate_Transform = transform { translate <3, 1, 2> }
#declare Composite_Transform =
    transform {
        No_Change_Transform
        Rotate_Transform
        Shear_Transform
        Translate_Transform
#debug "\nNo Change Transform:\n"
M_Print(M_FromTransform(No_Change_Transform))
#debug "\nRotate Transform:\n"
M_Print(M_FromTransform(Rotate_Transform))
#debug "\nShear Transform:\n"
M_Print(M_FromTransform(Shear_Transform))
#debug "\nTranslate Transform:\n"
M_Print(M_FromTransform(Translate_Transform))
#debug "\nComposite Transform:\n"
M_Print(M_FromTransform(Composite_Transform))
#debug "\n\n"
#declare No_Change_Matrix = M_Identity(4);
#declare Rotate_Matrix = M_Rotate3D_AroundX(radians(60));
#declare Shear_Matrix =
    array[4][4] {
        {  1.0,  1.0,  0.0,  0.0 },
        {  0.0,  1.0,  0.0,  0.0 },
        {  0.0,  0.0,  1.0,  0.0 },
        {  0.0,  0.0,  0.0,  1.0 }
#declare Translate_Matrix = M_Translate3D(<3, 1, 2>);
#declare Composite_Matrix =
    M_Mult(
        M_Mult(
            M_Mult(
                No_Change_Matrix,
                Rotate_Matrix
            Shear_Matrix
        Translate_Matrix
#debug "\nNo Change Matrix:\n"
M_Print(No_Change_Matrix)
#debug "\nRotate Matrix:\n"
M_Print(Rotate_Matrix)
#debug "\nShear Matrix:\n"
M_Print(Shear_Matrix)
#debug "\nTranslate Matrix:\n"
M_Print(Translate_Matrix)
#debug "\nComposite Matrix:\n"
M_Print(Composite_Matrix)
#debug "\n"
#error "No error, just finished"
Date: 25 Jan 2025 19:30:00
Message: <web.6795815028e999341f9dae3025979125@news.povray.org>
A matrix is nothing more than a statement of the end position of each basis
vector after the transformation.
For instance, when I do a shear along x, what I do is take "y" (<0, 1, 0>) and
shit it along the x-axis.  Maybe make it become <0.5, 1, 0>.
So matrix {
1, 0, 0,
0, 1, 0,
0, 0, 1,
0, 0, 0
becomes
matrix {
1, 0, 0,
0.5, 1, 0,
0, 0, 1,
0, 0, 0
Just think of the matrix operator as
matrix {
x,
y,
z,
translate <a, b, c>
and your matrix transform is
matrix {
new_x,
new_y,
new_z,
translate <a, b, c>
https://www.youtube.com/watch?v=kYB8IZa5AuE
https://www.f-lohmueller.de/pov_tut/trans/trans_000e.htm
Date: 25 Jan 2025 19:58:04
Message: <6795889c$1@news.povray.org>
> codecs.
> standard 8-bit?
Hi Kenneth,
Excepting - maybe - the noise video where output grayscale and I
remember trying the flag '-vf format=gray' to get a smaller mp4 file
(made no difference), everything should be 8 bits because the png output
is defaulting to 8 bits per channel.
Thank you for taking the time to investigate the problem you've seen
with my ffmpeg encoded videos! I'm an amateur having encoded very few
animations over the years - and I've posted fewer still.
I'd captured recommendations Dick Balaska made years ago for options
(which included a '-pix_fmt yuv420p' setting), however, when I tried the
command line late last year I kept getting errors I didn't understand.
Being lazy, I dropped back to a very simple command with a flag for
frame rate, the input pattern for saved image frames and the output file
name... Things seemed to work, so I went with ffmpeg's defaulting. :-)
Next time I create an animation with ffmpeg, I'll try to get the 4:2:0
chroma sub-sampling.
Bill P.
Date: 25 Jan 2025 22:35:00
Message: <web.6795aca928e99934e83955656e066e29@news.povray.org>
> > still have a hard time understanding how they work and how to use them.
> [clip]
Thanks for the useful info. Actually, the shearing ability of a matrix is one of
the (few) things that I do grasp. And William P's checkerboard rotation trick
has also been informative. But there are other more complex matrix transforms
that I have seen in newsgroup posts and include files that really baffle me, as
to how the 'magical' results are obtained. (Rune's old 'illusion.inc' file is a
prime example; I use it a lot, but its workings are a mystery to me.)
What I *need* to do is devote the time solely to learning the fundamentals-- and
without other POV-ray distractions. But that's difficult! Because there are
many *other* features that I only understand at a basic level...like
sophisticated functions! To truly learn all that I need to know, I could spend
25 hrs a day.
But every now and then, I have the urge to actually *render* something. ;-)
Date: 26 Jan 2025 10:28:52
Message: <679654b4$1@news.povray.org>
Thank you for the reminder. I'd looked at what you have there before -
but my memory failed me in moment.
While I was "thinking aloud" about what was happening with the checker
rotation/shear 'stick poking' play, your package would have saved me a
chunk of time.
I've added a link to your page from my yuqk matrix documentation text
file - which I hope will help me remember.
Bill P.
Date: 26 Jan 2025 14:25:00
Message: <web.67968baa28e999341f9dae3025979125@news.povray.org>
I have never used it, and the instructions puzzle me.
Perhaps if you could post a scene using it, and the intermediate render, then
maybe I can have some idea how to use it and see how it works.
Also, this seems like the sort of perspective correction that Francois LE COAT
would know all about.
- BW
Date: 27 Jan 2025 08:40:57
Message: <67978ce9@news.povray.org>
Alright. Found myself playing again today with a direct matrix transform
  against yuqk's updated wrinkle pattern. The attached animation uses
the sampling you suggested. Does it work in programs where failing before?
Bill P.
             matrix <
                 1.0, (frame_number-1)/60, 0.0,
                -(frame_number-1)/60, 1.0, 0.0,
                 0.0, 0.0, 1.0,
                 (frame_number-1)/57, (frame_number-1)/37, 0.0>
Download 'wrinkles.mp4.dat' (922 KB)
Date: 27 Jan 2025 10:50:00
Message: <web.6797aad828e99934e83955656e066e29@news.povray.org>
YES, this animation plays in all of my Windows media players, including
Irfanview. AND, it also plays in Firefox's 'preview'. Great work! Thanks for
taking the time to dig down into your settings for ffmpeg; very much
appreciated.
For this animation, my VLC Media Player does not report the particular 'chroma
subsampling' scheme that you used... but that seems to be its usual behavior
when encountering the 'typical' 4:2:0. So I guess the switch from 4:4:4 to 4:2:0
has solved the problem. That is interesting news! :-)
