"Kenneth" <kdw### [at] gmail com> wrote:
> It is basically a different
> way of applying an image_map to objects-- but from the camera's viewpoint, and
> with a rather magical matrix manipulation that alters the 'depth perspective' of
> the applied image.
Yes, I get that part.
> Rune's matrix transform is quite mysterious (to me) because it uses the
> *camera's* settings, along with some math manipulations that are presently way
> over my head.
So, as best I can tell, he's simply done the kind of thing that's done in the
"make this object/text always face the camera"... with the matrix.
but the image_map is converted to a function that incorporates x/z and y/z which
also corrects for the projection matrix so that everything lines up no matter
how near or far.
I just haven;t had the time to figure out how to start applying his include to a
scene, so that I can reverse-engineer it enough to provide a didactic diagram
and explanation.
So if you have working code.... ;)
- BW
> > {Illusion.inc] is basically a different
> > of the applied image.
> It essentially applies the image_map as an 'orthographic' projection onto scene
> objects, devoid of perspective... which is quite different from a typical
> map_type 0 projection.
So, I spent a bit of time working out how to do the "this object always faces
the camera" thing, and it's essentially what gets done in screen.inc, minus the
final translation.
Compare that to Rune's "rather magical matrix manipulation" and you'll see that
it's basically the same thing.
So it looks to me that what's going on is, the image gets oriented to be
perpendicular to the camera / parallel to the image plane, and the divisions by
z in the image function are there to provide the appropriate scaling of the
image depending upon where it gets mapped to.
- BW
Download 'facecamera.pov.txt' (2 KB)
> the camera" thing,
And here's a bit more commentary to better explain how that works, and provide a
useful bit of code for future reference.
#macro FaceCamera (Object, CL)
#local Min = min_extent (Object);
#local Max = max_extent (Object);
#local OL = Min + (Max-Min)/2;
#declare CamL = CameraLocation; // wherever you're putting it
#declare CamD = vnormalize (OL-CamL); // direction of camera view
// One can alternately look at this as -Caml, translated to the object's
// location by adding OL. -CamL+OL = (OL-CamL)
#declare CamR = vnormalize (vcross(y,CamD)); // to the right
// The vector cross product gives a vector that is perpendicular to the two
// given vectors. If we're at the vertex (camera location) and we cross the
// direction of view and the y-axis, we get a vector pointing out to the right
// CamD and y are likely not perpendicular, so the resulting vcross is some
// size != 1, so we normalize the size.
#declare CamU = vnormalize (vcross(CamD,CamR)); // camera up
// So now we have a view direction and a right vector, which are perpendicular
// So we do another vector cross product, and get the new "up" vector
// Which completes our new "frame of reference".
// The tangent, normal, and binormal unit vectors, often called T, N, and B,
// or collectively the Frenet–Serret frame (TNB frame or TNB basis)
// So now when we take the old x, y, and z basis vectors or normal POV-space
// and move them to align with the new TNB vectors, your object whose
// orientation was based upon x, y, and z is now based upon the new
// T, N, and B vectors.
// Since default camera points at z, and default orientation of most objects
// is in the xy plane, the object is now in the same relative orientation
// to the camera in the new TNB frame, and so always faces the camera.
#declare Object_Transform =
transform {
matrix <
CamR.x, CamR.y, CamR.z,
CamU.x, CamU.y, CamU.z,
CamD.x, CamD.y, CamD.z,
0, 0, 0
object {
Object
transform {Object_Transform}
#end // end macro FaceCamera
Download 'always facing the camera.txt' (2 KB)
On 1/25/2025 6:47 AM, Kenneth wrote:
> So I downloaded your video-- and it plays fine in*most* of my Windows 10 media
> players: VLC Media Player, SM Player, and even my old VirtualDub2. But it does
> not play in Windows' own Media Player (a black screen)-- and actually breaks
> Irfanview (the app hangs and has to be terminated via Windows Task Manager.)
> Irfanview will usually play just about any video that I throw at it, so its
> behavior in this case is very weird.
> In VLC Media Player, I took a look at your first posted video's encoding
> statistics:
> Codec: H264-MPEG-4 AVC (part 10) (avc1)
> Video Resolution: 450 X 450
> Buffer Dimensions: 464 X 482
> Decoded Format: Planar 4:4:4 YUV
> Color Primaries: ITU-R BT.709
> I did some research (yet again!) about video encoding and codecs, because it is
> all so complicated to remember. Your video's stats are fairly standard stuff
> AFAIU-- except for the 4:4:4 chroma subsampling. 4:2:0 is the typical scheme
> for h.264; I use that myself. Take a look at Wikipedia's "h.264" page,
> particularly the subsection "Feature support in particular profiles". It appears
> that 4:4:4 is only supported in a particular high-end 'flavor' of h.264; perhaps
> that presents a problem for Firefox, and/or for Windows 10's built-in video
> codecs.
I'm late to reviewing this thread. I use ffmpeg on Windows 10 to make my
animations.
ffmpeg -i <file_pattern> -c:v libx264 -strict -2 -preset slow -pix_fmt
yuv420p -vf "scale=trunc(iw/2)*2:trunc(ih/2)*2" -f mp4 candle2.mp4
I think it's the -pix_fmt yuv420p that makes Windows Media Player like
the file. It might by the -c:v libx264 that's doing it though. It's been
a while and I don't remember.
Josh
