POV-Ray : Newsgroups : povray.binaries.animations : Playing with matrix transforms Server Time
18 Jun 2026 00:41:19 EDT (-0400)
  Playing with matrix transforms (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Playing with matrix transforms
Date: 25 Jan 2025 19:58:04
Message: <6795889c$1@news.povray.org>
On 1/25/25 09:47, Kenneth wrote:
> I did some research (yet again!) about video encoding and codecs, because it is
> all so complicated to remember. Your video's stats are fairly standard stuff
> AFAIU-- except for the 4:4:4 chroma subsampling.  4:2:0 is the typical scheme
> for h.264; I use that myself. Take a look at Wikipedia's "h.264" page,
> particularly the subsection "Feature support in particular profiles". It appears
> that 4:4:4 is only supported in a particular high-end 'flavor' of h.264; perhaps
> that presents a problem for Firefox, and/or for Windows 10's built-in video
> codecs.
> Or maybe you encoded the videos using 10-bit colors rather than the more
> standard 8-bit?
Hi Kenneth,
Excepting - maybe - the noise video where output grayscale and I
remember trying the flag '-vf format=gray' to get a smaller mp4 file
(made no difference), everything should be 8 bits because the png output
is defaulting to 8 bits per channel.
Thank you for taking the time to investigate the problem you've seen
with my ffmpeg encoded videos! I'm an amateur having encoded very few
animations over the years - and I've posted fewer still.
I'd captured recommendations Dick Balaska made years ago for options
(which included a '-pix_fmt yuv420p' setting), however, when I tried the
command line late last year I kept getting errors I didn't understand.
Being lazy, I dropped back to a very simple command with a flag for
frame rate, the input pattern for saved image frames and the output file
name... Things seemed to work, so I went with ffmpeg's defaulting. :-)
Next time I create an animation with ffmpeg, I'll try to get the 4:2:0
chroma sub-sampling.
Bill P.
Date: 25 Jan 2025 22:35:00
Message: <web.6795aca928e99934e83955656e066e29@news.povray.org>
> "Kenneth" <kdw### [at] gmailcom> wrote:
> > That is also my usual method of playing with matrices, ha-- because I
> > still have a hard time understanding how they work and how to use them.
> A matrix is nothing more than a statement of the end position of each basis
> vector after the transformation.
> [clip]
Thanks for the useful info. Actually, the shearing ability of a matrix is one of
the (few) things that I do grasp. And William P's checkerboard rotation trick
has also been informative. But there are other more complex matrix transforms
that I have seen in newsgroup posts and include files that really baffle me, as
to how the 'magical' results are obtained. (Rune's old 'illusion.inc' file is a
prime example; I use it a lot, but its workings are a mystery to me.)
What I *need* to do is devote the time solely to learning the fundamentals-- and
without other POV-ray distractions. But that's difficult! Because there are
many *other* features that I only understand at a basic level...like
sophisticated functions! To truly learn all that I need to know, I could spend
25 hrs a day.
But every now and then, I have the urge to actually *render* something. ;-)
Date: 26 Jan 2025 10:28:52
Message: <679654b4$1@news.povray.org>
On 1/25/25 19:22, Tor Olav Kristensen wrote:
> For those of you that want to be able to do matrix calculations within POV-Ray,
> I have made a library that can do some of that.
> It can be found here:
> https://github.com/t-o-k/POV-Ray-matrices
Thank you for the reminder. I'd looked at what you have there before -
but my memory failed me in moment.
While I was "thinking aloud" about what was happening with the checker
rotation/shear 'stick poking' play, your package would have saved me a
chunk of time.
I've added a link to your page from my yuqk matrix documentation text
file - which I hope will help me remember.
Bill P.
Date: 26 Jan 2025 14:25:00
Message: <web.67968baa28e999341f9dae3025979125@news.povray.org>
I have never used it, and the instructions puzzle me.
Perhaps if you could post a scene using it, and the intermediate render, then
maybe I can have some idea how to use it and see how it works.
Also, this seems like the sort of perspective correction that Francois LE COAT
would know all about.
- BW
Date: 27 Jan 2025 08:40:57
Message: <67978ce9@news.povray.org>
Alright. Found myself playing again today with a direct matrix transform
  against yuqk's updated wrinkle pattern. The attached animation uses
the sampling you suggested. Does it work in programs where failing before?
Bill P.
             matrix <
                 1.0, (frame_number-1)/60, 0.0,
                -(frame_number-1)/60, 1.0, 0.0,
                 0.0, 0.0, 1.0,
                 (frame_number-1)/57, (frame_number-1)/37, 0.0>
Download 'wrinkles.mp4.dat' (922 KB)
Date: 27 Jan 2025 10:50:00
Message: <web.6797aad828e99934e83955656e066e29@news.povray.org>
YES, this animation plays in all of my Windows media players, including
Irfanview. AND, it also plays in Firefox's 'preview'. Great work! Thanks for
taking the time to dig down into your settings for ffmpeg; very much
appreciated.
For this animation, my VLC Media Player does not report the particular 'chroma
subsampling' scheme that you used... but that seems to be its usual behavior
when encountering the 'typical' 4:2:0. So I guess the switch from 4:4:4 to 4:2:0
has solved the problem. That is interesting news! :-)
Date: 31 Jan 2025 07:57:31
Message: <679cc8bb@news.povray.org>
On 1/19/25 15:33, William F Pokorny wrote:
> Playing more with matrix transforms
Recently the idea of splines as interpolations was touched upon in the
thread:
https://news.povray.org/povray.advanced-users/thread/%3Cweb.6797e39ce9acc1774cc51b5c25979125%40news.povray.org%3E/
Perhaps obvious the matrix play in this thread can act as a rotational
interpolation.
Attached an animation and full scene file for the animation (for jr). It
should run in v3.8 beta 2 too.
Bill P.
Download 'interpolatematrix.mp4.dat' (391 KB) Download 'interpolatematrix.pov.txt' (4 KB)
Date: 31 Jan 2025 09:25:00
Message: <web.679cdc7028e9993425b4de9225979125@news.povray.org>
> interpolation.
Well now that we're going there - Bezier and other splines can all be
represented as matrix multiplications.
https://blog.demofox.org/2016/03/05/matrix-form-of-bezier-curves/
https://observablehq.com/@danburzo/the-matrix-form-of-some-common-cubic-splines
I know that clipka was talking about trying to find as much common ground for
all of the primitives as possible, so that we could have as few specialized
objects/data structures as possible, so perhaps it would good to look at a lot
of the spline/interpolation code as matrix-based.
We ought to have robust and versatile matrix methods available anyway.
Also, rotational matrices tie directly into complex numbers - so maybe there's a
way to roll that in there too.
- Bald "I want it all" Eagle
Date: 31 Jan 2025 10:10:00
Message: <web.679ce6fd28e9993417bac71e8ffb8ce3@news.povray.org>
There are a few fun things one can do with the matrix based spline calculations.
One can blend two spline matrices to a new spline, or over time morph from one
spline to an other spline type. But one needs access to POV-Ray's internals
then.
The whole spline matrices thing is covered here:
http://web.archive.org/web/20151002232205/http://home.comcast.net/~k9dci/site/?/page/Piecewise_Polynomial_Interpolation
Download the book PDF and the separate appendix.
ingo
Date: 3 Feb 2025 12:25:00
Message: <web.67a0fafa28e99934e83955656e066e29@news.povray.org>
> > Rune's old 'illusion.inc' file is a prime example [of a complex matrix];
(Sorry for the delay, I was updating my own notes about illusion.inc and running
more test renders.)
Yeah, it was confusing to me as well when I first tried to use it-- mainly
because it is set up as a demonstration file rather than a basic include. And
the demonstration results are a bit confusing, IMO. It is basically a different
way of applying an image_map to objects-- but from the camera's viewpoint, and
with a rather magical matrix manipulation that alters the 'depth perspective' of
the applied image.
It is still available at
https://runevision.com/3d/include/
(Rune mentions that the download has a 2010 update by Sam Benge, which is
apparently no longer part of it; I checked recently.)
Back in 2013, I posted some preliminary info about how the include file works:
https://news.povray.org/povray.binaries.images/thread/%3Cweb.5106f53bd9b7ab13c2d977c20%40news.povray.org%3E/
I also posted a kind of explanatory animation at the time, but it is in
an older .avi video format:
https://news.povray.org/povray.binaries.animations/thread/%3Cweb.5106fb628df1613ec2d977c20%40news.povray.org%3E/?ttop=4
44658&toff=150
I should mention have been using my own simplified and slightly updated version
of the include file for years. I've had thoughts of posting it-- along with my
own set of instructions and a different demo-- but was worried that it might
infringe on Rune's original copyright notice from 2003. Although, I now see that
an update would probably be OK to post.
Rune's matrix transform is quite mysterious (to me) because it uses the
*camera's* settings, along with some math manipulations that are presently way
over my head.
