POV-Ray : Newsgroups : povray.binaries.animations : Textured flexible cylinder Server Time
31 Dec 2025 07:54:45 EST (-0500)
  Textured flexible cylinder (Message 1 to 3 of 3)
Subject: Textured flexible cylinder
Date: 26 Apr 2024 13:15:52
Message: <662be148@news.povray.org>
Attached is a cylinder bent around a circular arc.
How did I get the texture to follow the bend?  Easy: I spent 3 days
throwing spaghetti at a wall until all of it stuck.
I have to do this every time I use the cylindrical warp.  I can explain
all about how POV-Ray handles gamma and sRGB, but warp { cylindrical }
is still black magic to me.
The code will be in the next major release of DeskLamp.
Download 'test_flex_texture.mp4.dat' (123 KB)
Subject: Re: Textured flexible cylinder
Date: 26 Apr 2024 21:05:00
Message: <web.662c4e91703632a81f9dae3025979125@news.povray.org>
Well, to be fair, you're doing one of those Cousin-Ricky level things that I
often find myself doing.
Cylindrical means cylindrical.
And you're deviating from that to toroidal.
If I had to guess the best way to do that, it would be by geometric inversion.
Your cylinder would be a torus of infinite radius, and then you'd translate it
relative to the center of inversion until you got a torus with the desired major
radius.
Dunno if recounting my cylindrical warp woes will help you any:
http://news.povray.org/povray.bugreports/thread/%3Cweb.5c01b8a81374e197765e06870%40news.povray.org%3E/
Excellent job getting it all to work!
I'm sure it must have been a hard slog to the finish line.
- BE
Date: 26 Apr 2024 21:53:34
Message: <662c5a9e$1@news.povray.org>
My intended task was to bend a solid texture into an arc.  That it is
applied to a torus is incidental.  I can't even begin to imagine dealing
with warp { toroidal }.  (What you see in the animation is a solid
checker pattern.  If I were dealing with uv-mapping, of course I would
have used toroidal.)
> radius.
I suppose if I were doing those calculations myself, I'd at least know
what I was doing.  But without thinking too hard about it, it seems like
an overly convoluted and unnecessarily difficult way to get it done.
The main difficulty with warp { cylindrical } was getting all the parts
oriented and scaled properly, but the end code is remarkably simple, if
somewhat head-scratching.
FWIW, I did work from the center of curvature, then translate.  And of
course, the unbent object (which does not appear in this animation,
because it is between frames) is a special case using a straight
cylinder, because infinite radii and translations are not fun.
Thanks!
