POV-Ray : Newsgroups : povray.binaries.animations : Flying Rocks Server Time
6 Mar 2026 18:06:24 EST (-0500)
  Flying Rocks (Message 1 to 3 of 3)
Subject: Flying Rocks
Date: 8 May 2017 05:50:38
Message: <59103f6e$1@news.povray.org>
My latest WIP.
http://www.buckosoft.com/tteoac/
Bonus features > flyingRocksDev
This demonstrates the evolution of a box of rocks falling into the
fishtank, in the same vein as my mushroomDev video.  But mostly it is an
excuse to use a piece of music with me shredding on my strat. ;)
dik
Subject: Re: Flying Rocks
Date: 10 May 2017 16:50:00
Message: <web.59137bd8cfb65e1bf591106d0@news.povray.org>
Interesting to see the falling rocks sequence evolve. Is it all generated via
custom collision detection and physics modelling, or did you re-use
off-the-shelf software for that? The final sequence looks impressive.
Two comments though. The balls jiggle a bit too much at the bottom of the
aquarium to be realistic. Also, while falling the column of balls remains a bit
too static I feel. When falling in air, the balls would speed up, so their
distance should increase as they are going down. In water the effect may be less
pronounced. However, due to the extra friction and turbulence of the water, I
would then expect a bit more sideways movement. Maybe you can tweak your
algorithm a bit too fudge this? (Realistic modelling of turbulence and friction
of the objects might be a bit too difficult...)
Date: 11 May 2017 00:54:36
Message: <5913ee8c$1@news.povray.org>
Am 2017-05-10 16:45, also sprach Eriban:
yes. Custom java emitting SDL.
http://git.buckosoft.com/gitweb/pov.cgi?p=TteoacService.git;a=blob;f=src/main/java/com/buckosoft/povspew/tteoac/Fishtank/FishtankRunner.java;hb=HEAD
> or did you re-use
Thanks.
Yeah, this bothers me too.  I *do* like the effect, somewhat, though.
It looks almost molecular.  Perhaps the laws of physics on Planet Bucko
allow for infinite hardness. :)  The problem is, the energy of a top
rock is transferred to a bottom rock, who then has to transfer it back
because the tank bottom doesn't move.  The opposite problem is, I want
the rocks to spread out on the bottom of the tank and if I absorb all of
the energy, so they stop jittering, they end up in a slumped pile in the
corner.
I already had to cheat this. In order to get the full tank coverage in
the time I allotted, I had to speed up the clock. (I think the sped up
clock contributes to the static looking initial falling column)
> too static I feel.
Yes, especially the initial part. Static is a great word for it. I do
like the little plume when they first hit the tank bottom.
> pronounced.
Terminal velocity in water is much less than in air. The rocks speed up
in the air, but the "water" is at the top of the tank and the rocks
don't spend much time in the air.
I expected more sideways movement too. But, a sphere in water at any
vector is going to rapidly decay to straight down. There's no hydrofoil
to channel the water.
I'm thinking on it.  A rock is radius .25. I thought about filling the
tank with radius .01 water (just for calcs, not to display) so I can
track the currents better.  I think to do that, I'd have to switch from
Java to c++ and I don't know if I want to write the framework just to
support that.
dik
