POV-Ray : Newsgroups : povray.binaries.animations : Pannellum Server Time
11 Oct 2026 17:14:27 EDT (-0400)
  Pannellum (Message 1 to 23 of 23)
Subject: Pannellum
Date: 2 Apr 2017 20:51:55
Message: <58e19cab$1@news.povray.org>
I updated my spaceship scene and rendered new frames to be used with
Pannellum panorama viewer.
http://isometricland.net/panorama/pannellum.htm?config=pano-gh-scene-spinner.json
I still was not able to turn the interior atmosphere due to render
times. Even on the 16-core MS Azure server I am using for my renders
this month, things were taking too long.
Enjoy.
Mike
Subject: Re: Pannellum
Date: 2 Apr 2017 21:07:39
Message: <58e1a05b$1@news.povray.org>
> Enjoy.
> Mike
Forgot to mention there are strange square shaped artifacts in the blue
end caps of the scene. They exist in the source images as well. I don't
know what causes them.
Mike
Date: 3 Apr 2017 04:55:00
Message: <web.58e20cefd40b65bd9c5d6c810@news.povray.org>
Impressive scene. And maybe disorienting to some earthbound people. :)
If able to see it, is the atmosphere both ground-hugging and cloudlets floating
around?
Wild guess about the squares. Could it be something about the ends being
directly opposite and slightly reflective, max_trace_level?
Although I don't recall seeing unusual squared patterns from anything like that
before.
Date: 3 Apr 2017 05:40:02
Message: <58e21872$1@news.povray.org>
Yes it is impressive. :)
> around?
> before.
I would definitely check the max level first.
When you were making the trefoil, is there anything with an unusual
normal involved?
Regards
Date: 3 Apr 2017 08:14:00
Message: <58e23c88$1@news.povray.org>
Am 03.04.2017 um 03:08 schrieb Mike Horvath:
Looks like radiosity artifacts to me.
Your scene may need a more exhaustive radiosity pretrace.
Make sure you have `always_sample` set to `off` (or not set at all).
Date: 3 Apr 2017 12:35:20
Message: <58e279c8$1@news.povray.org>
Here are my global settings. Radiosity is disabled.
global_settings
	charset utf8
	assumed_gamma	1.0
	#if (!NoRadiosity)
		ambient_light	0
		radiosity
			pretrace_start	0.08
			pretrace_end	0.02
			count			20
			error_bound		1
			recursion_limit	1
			normal			on
			brightness		0.8
			always_sample	no
			gray_threshold	0.8
			media			on
	#switch (TexQual)
		#case (-1)
			max_trace_level 4
		#break
		#case (0)
			max_trace_level 4
		#break
		#case (1)
			max_trace_level 4
		#break
		#case (2)
			max_trace_level 4
		#break
Mike
Date: 3 Apr 2017 12:37:06
Message: <58e27a32$1@news.povray.org>
Thanks!
> around?
No, it is a constant density.
> before.
It could be, since I have it set very low.
Mike
Date: 3 Apr 2017 14:10:32
Message: <58e29018$1@news.povray.org>
Am 03.04.2017 um 18:36 schrieb Mike Horvath:
Then I have no idea what might cause the artifacts.
Date: 3 Apr 2017 15:50:01
Message: <web.58e2a6b4d40b65bd9c5d6c810@news.povray.org>
> > around?
Ah, okay, I was using my imagination anyway. No I'm wondering what that would do
in the spiral light... if that is a light.
> > before.
What is really strange about it, to me, is how one of the nearby artifacts
(after moving scene around) appears to have a 90 degree angle going on.
The square shapes form a sort of floor and wall, if thinking of it as partially
covering tiles without seams where they meet.
Hopefully you can see or find that too.
Date: 4 Apr 2017 06:00:01
Message: <web.58e36e8bd40b65bd883fb31c0@news.povray.org>
> global_settings
>  charset utf8
[snip]
Although I haven't seen your animation yet, the   charset utf  entry caught my
eye. Wasn't there another recent post about artefacts due to that? I think it
was in the post about the "Dokken" logo not rendering correctly.
Date: 4 Apr 2017 09:25:36
Message: <58e39ed0$1@news.povray.org>
Am 03.04.2017 um 21:47 schrieb omniverse:
My guess is that the 360 degree image format is using a cube model, and
what you see is the edge of that box.
Date: 4 Apr 2017 09:27:55
Message: <58e39f5b$1@news.povray.org>
Am 04.04.2017 um 11:59 schrieb Kenneth:
>> global_settings
>>  charset utf8
> [snip]
"charset utf8" can't give you genuine render artifacts. It can only give
you wrong character shapes in a `text` object.
Date: 4 Apr 2017 22:17:03
Message: <58e4539f$1@news.povray.org>
Yes, it uses 6 images to form a cube map. The artifacts are distributed
randomly across each of the 6 images.
Mike
Date: 4 Apr 2017 22:21:18
Message: <58e4549e$1@news.povray.org>
>> Enjoy.
>> Mike
> Mike
Forgot to say I think the artifacts are the same size as the "render
blocks" (or whatever they're called) when rendering any scene. Sort of
like the mosaic preview.
Mike
Date: 6 Apr 2017 18:15:44
Message: <58e6be10$1@news.povray.org>
> Enjoy.
> Mike
I rendered a higher resolution version of the scene.
It includes some but not all of the fixes I have been working on over
the last few days. I will probably do another render sometime soon,
though not at the same high resolution because it takes so long.
Mike
Date: 6 Apr 2017 18:35:27
Message: <58e6c2af$1@news.povray.org>
>> Enjoy.
>> Mike
Okay I'll bite. How long did it take?
It is really good.
What's puzzling me is what looks like a shadow along the three arms of
the support.
Regards
Date: 6 Apr 2017 20:05:12
Message: <58e6d7b8@news.povray.org>
It took 2-3 days on a rented Microsoft Azure server. On my home PC it
would have taken 7-10 days I think. That's without the atmospheric media
I wanted to use in the scene, or the radiosity.
> It is really good.
Thanks! I have been working on it since ~2010 I think. Maybe earlier.
> the support.
I don't know either.
Mike
Date: 6 Apr 2017 20:34:21
Message: <58e6de8d$1@news.povray.org>
Ah! that's not CPU ticks I hear. It is the sound of cents draining out
of your pocket. ;)
It was worth it. :)
>> It is really good.
I remember the early posts and versions. Then you went quiet.
>> the support.
The strange thing is it looks familiar. I used a similar shape for a
flywheel, years ago.
Regards
Date: 6 Apr 2017 22:51:04
Message: <58e6fe98$1@news.povray.org>
> of your pocket. ;)
> It was worth it. :)
Well, I am using the free trial period/balance you get when you create
an account. You get $200 which you can spend in 30 days. I have almost
used all $200.
Google offers $300 that you can spend in 12 months, as well as a
discount if you use Linux instead of Windows. I will be doing that next.
>>> It is really good.
I put it aside as render times were getting too long using just my home
PC. I am impatient.
>>> the support.
The "caps" on each end of the habitat are actually a little concave,
too, like a dish. Maybe that is influencing the render?
Mike
Date: 7 Apr 2017 06:09:50
Message: <58e7656e$1@news.povray.org>
>> of your pocket. ;)
>> It was worth it. :)
> used all $200.
It is certainly cheaper and tidier than buying hardware.
>>>> It is really good.
> PC. I am impatient.
I've lost count of the projects I've abandoned for that reason.
>>>> the support.
I've had a look at some of my old files and think I must be remembering
one of your original posts that puzzled me. (At least my long term
memory is still working. ;) )
Regards
Date: 7 Apr 2017 08:30:01
Message: <web.58e7853fd40b65bdddf562da0@news.povray.org>
This is really nice - and really the only way to look at scenes like this!
Have you tried rendering it from 'ground level', as an inhabitant would see it?
Bill
Date: 7 Apr 2017 08:36:58
Message: <58e787ea$1@news.povray.org>
>>>> media
>>> of your pocket. ;)
>>> It was worth it. :)
>> used all $200.
>>>>> It is really good.
>> PC. I am impatient.
>>>>> the support.
Source code is available here:
http://www.mediafire.com/file/gp2q0br1737h9du/GH_LoadingScreen_src_v2_9_0.zip
It is in the "gh_scene_spinner" directory. The file name is
"gh_scene_spinner_interior_b.pov". Good luck tracking down all the
dependencies however!
Mike
Date: 7 Apr 2017 14:42:58
Message: <58e7ddb2$1@news.povray.org>
> Bill
I'm afraid there won't be much to see at ground level except some very
primitive looking people models.
Mike
