POV-Ray : Newsgroups : povray.binaries.animations : CIELCHuv D65 gamut sphere Server Time
25 Mar 2026 01:21:50 EDT (-0400)
  CIELCHuv D65 gamut sphere (Message 1 to 10 of 16)
Subject: CIELCHuv D65 gamut sphere
Date: 25 Mar 2017 04:19:10
Message: <58d627fe@news.povray.org>
The visible gamut under D65 illumination mapped to spherical CIELCHuv
coordinates.
Mike
Download 'visible_lchuv_d65_sph_f.webm.dat' (2073 KB)
Subject: Re: CIELCHuv D65 gamut sphere
Date: 25 Mar 2017 05:21:46
Message: <58d636aa@news.povray.org>
Am 25.03.2017 um 09:19 schrieb Mike Horvath:
> coordinates.
You seem to be interpreting L as a polar coordinate, which is rather
unconventional -- and as a matter of fact doesn't make much sense, since
it causes all grey tones to collapse into the center.
The official CIE LCh colout space is cylindrical in nature, not
spherical (though the visible gamut under D65 might take on a somewhat
spherical shape).
Date: 25 Mar 2017 07:21:55
Message: <58d652d3@news.povray.org>
>> coordinates.
> spherical shape).
Yes, I know. Adding a bit to the beginning of the radius creates a hole
that keeps the gray values from collapsing.
Mike
Date: 25 Mar 2017 09:46:42
Message: <58d674c2$1@news.povray.org>
Am 25.03.2017 um 12:22 schrieb Mike Horvath:
>>> coordinates.
>> spherical shape).
Why use this non-canonical representation of CIE LCh/Luv in the first place?
Date: 25 Mar 2017 11:08:52
Message: <58d68804@news.povray.org>
>>>> coordinates.
>>> spherical shape).
Back when I was learning how to use paint programs, before I learned
what a color solid was, I came up with a spherical representation of the
HSL color model (see attachment). I always liked the shape, and it stuck
with me.
Mike
Download 'hsl_sphere_color_solid.fs.png' (419 KB)
Preview of image 'hsl_sphere_color_solid.fs.png'
Date: 25 Mar 2017 11:38:19
Message: <58d68eeb$1@news.povray.org>
Am 25.03.2017 um 16:09 schrieb Mike Horvath:
>>>>> coordinates.
>>>> since
>>>> spherical shape).
>> place?
> with me.
Beware that the parameterization of that color solid differs
significantly from that of your CIE LCh animation: In this HSL solid, S
is quite clearly measured radially from the vertical axis. In your CIE
LCh animation, the corresponding parameter C seems to be measured
radially from the center.
Date: 25 Mar 2017 13:36:28
Message: <58d6aa9c@news.povray.org>
Nope. It is from the center point too.
Mike
Date: 25 Mar 2017 16:19:47
Message: <58d6d0e3$1@news.povray.org>
Am 25.03.2017 um 18:36 schrieb Mike Horvath:
Just read up on HSL, and you are right: In your spherical HSL diagram,
the distance from the center of the spehere does indeed correspond to
the parameter called "Saturation" in the HSL model.
*BUT* that "Saturation" parameter differs significantly from what I'd
consider the physical definition of saturation, where only monochromatic
light would be defined as fully saturated, while white light (at any
brightness, i.e. any shade of grey if you will) would be considered
fully unsaturated, which is what the "Chroma" parameter in the CIE LCh
model corresponds to.
If you want to get anywhere close to your HSL sphere with the CIE LCh
model, you have to represent the "Chroma" parameter as distance from the
vertical axis, otherwise you'll get a torus-ish shape instead of a
sphere-ish one. I also /think/ you'd get closer to your ideal by
sticking to the fully canonical rendering, with the "Lightness"
parameter represented as distance from the bottom plane.
At any rate, publishing a non-canonical representation of the CIE LCh
model will certainly do more to confuse people about the colour model
than to educate them.
Date: 25 Mar 2017 17:38:00
Message: <58d6e338$1@news.povray.org>
https://commons.wikimedia.org/wiki/File:HSLSphere.svg
Is this image easier to understand? It is missing the "donut hole" in
the middle, however. So all the grays collapse to a point, unfortunately.
Do these figures show what you are talking about?
https://en.wikipedia.org/wiki/File:Hsl-hsv_saturation-lightness_slices.svg
It seems "chroma" needs to be converted to "saturation first". Not sure
the best way to do this, as I haven't thought of it before.
I'm not concerned so much with the outer shape. The spherical
parameterization is what's important to me. But "chroma" needs to be
converted to "saturation" first, as in the above image.
I labeled all the images as "original research", and nothing links to
them except a user page.
Mike
Date: 25 Mar 2017 18:14:31
Message: <58d6ebc7$1@news.povray.org>
Am 25.03.2017 um 22:38 schrieb Mike Horvath:
No, it's the HSL model's definition of "Saturation" in general that I
find counter-intuitive, not your visual representations of the HSL
colour solids.
Fair enough.
