Subject: Flight around Phobos, new version
Date: 18 Jan 2015 12:46:41
Message: <54bbf181@news.povray.org>
Hi(gh)!
After five years, I thought it was time for a new version of my "Flight
around Phobos" animation on YouTube... so this time and with a faster
computer, I decided to do the thing in 1024 by 768 pixels, also with a
higher-resolved (and somewhat brighter) texture for Phobos, furthermore
giving Mars some simple media atmosphere (I had a certain Viking photo
of Mars' limb above Argyre Planitia in mind, where the atmosphere in
fact looks like reddish-brown... on more recent images, the atmosphere
is bluish towards the limb) and using a dim brownish light placed
between Mars and Phobos for the illumination by Marsshine on Phobos'
night side.
Originally, I wanted to use radiosity for this - but as radiosity is
calculated for each frame individually, it resulted in a flickering
appearance of the portions of Phobos which are illuminated this way.
Also, with radiosity the Sun sphere in is media glow appeared grey
instead of white.
Rendering the 1440 frames was somewhat cumbersome, as I could not use
the same overall scaling factor (through which all vectors and distances
are divided) throughout the whole animation, sooner or later parts of
Phobos began to be clipped away, so I had to change between many
different values, from 5000 to somewhat over 15000.
Here you can view the animation (preferably at 720p HD in full-screen
mode): https://www.youtube.com/watch?v=atUTtI5xGPk
While writing this post, also a new version of the Deimos video is
rendered - I probably will upload it this evening (CET).
See you in Khybespace!
Yadgar
Now playing: Why Look for the Key (Howard Jones)
Very nice animation.
Both of your animations are very nice and impressive indeed. Deimos still seems
to have a little problem with a seam at one side, but only a minor flaw IMO.
Usually one shouldn't do this, but with a smooth mesh (with no sharp edges) one
can try to use it as an object pattern within an isosurface. In general it
doen't work due to infinite gradients but with smooth transitions only one can
give this a try. But no uv-mapping in this case.
Best regards,
Michael
Now playing: Redeemer of Souls (Judas Priest ;-)
I recently saw the old version, and although that was not bad, compared to it,
this new version is a clear improvement. Also, it's great that POV-Ray allows
you to make animations of objects in space without actually having to send a
rocket to it.
Cheers,
Erwin
