POV-Ray : Newsgroups : povray.binaries.animations : POVghanistan, a very first animation... Server Time
27 Nov 2026 12:39:52 EST (-0500)
  POVghanistan, a very first animation... (Message 1 to 5 of 5)
Subject: POVghanistan, a very first animation...
Date: 16 Jul 2013 18:29:07
Message: <51e5c933$1@news.povray.org>
Hi(gh)!
POVghanistan: Paghman Range Panorama
http://www.youtube.com/watch?v=R5pCZdj_VGM
After fixing the triangle gaps problem (see entry in p.b.i), I rendered
my first small animation of a vista point in POVghanistan... to be
precise, a mountain saddle in the 4,630-metres Paghman Range west of
Kabul. Due to RAM limitations, I currently can use only one
square-degree ASTER data tile at a time, this will probably not change
in the nearer future (even now, POV-Ray's peak memory usage is 14.2 GB!).
In the coming weeks, I may add smooth triangles and a more elaborate sky
and atmosphere model, preferably that of Bruno Cabasson.
Later on, I may render animations of low-altitude overflights covering
more than one data tile, carefully customizing mesh2s to contain as much
terrain as possible toward the horizon in viewing direction...
See you in Khyberspace!
Yadgar
Subject: Re: POVghanistan, a very first animation...
Date: 17 Jul 2013 16:01:40
Message: <51e6f824@news.povray.org>
‘Lo(w)!
I really think that you are getting there, with this. Smooth triangles
would make it look much, much better IMO. Is it much work?
Regards
Date: 17 Jul 2013 16:15:01
Message: <web.51e6fae68b9d266888cde25c0@news.povray.org>
> ‘Lo(w)!
> Regards
>      Stephen
I observed the same, but I observed even with this very high resolution
height_field I used for Mount Rainier (over 16000x16000 resolution) that in
close ups smooth doesn't work and you have the same as with Joergs animation.
Best regards,
Michael
Date: 18 Jul 2013 07:06:47
Message: <51e7cc47$1@news.povray.org>
Hi(gh)!
> ‘Lo(w)!
Yes, it would be. Because I would have to calculate the normal list
PRIOR to the face definitions - but as each normal should be the average
of the normals of the triangles adjacent to each corresponding vertex
(one at the northwestern and southeastern corner, two at the
northeastern and southwestern corner, three at the edges and six with
all others), the normals of the triangles and thus the triangles
themselves must be defined before!
And, yes, provided I got the correct method for averaging the normals,
smooth triangles would look indeed much better - but as the smoothness
is faked, it comes at the cost of producing strange sights when placing
objects (vegetation, houses etc.) on the mesh...
So instead I look for a method to generate isosurfaces from my
1-square-degree earth surface slices... I think it would start with a
pigment function derived from the original elevation heightfield (which
I also had to generate from DEM data in a non-POV format)... but this
pigment would be an imagemap constrained to a certain geographical
region of a sphere rather than simply mapped around the sphere.
I asked the question whether this could be doable with POV-Ray about two
weeks before on p.b.i., meanwhile also on a German POV-Ray forum, but
received no useful answers yet.
Yadgar
Date: 18 Jul 2013 13:29:06
Message: <51e825e2$1@news.povray.org>
   Maybe my HF2ISO experiments can give you some ideas (except for the
spherical part):
http://www.ignorancia.org/en/index.php?page=Heightfield_based_Isosurfaces
Jaime
