POV-Ray : Newsgroups : povray.binaries.animations : Babylon Server Time
7 Mar 2026 00:24:16 EST (-0500)
  Babylon (Message 1 to 10 of 11)
Subject: Babylon
Date: 22 Feb 2011 07:40:31
Message: <4d63aebf$1@news.povray.org>
Since mid december I've been working on an animated music-video.  The
music was made a couple of years ago, the animation was finished about a
week ago. Here's the result:
http://www.youtube.com/watch?v=oAckZrhGN3U
I hope you all like it!
cu!
ZK
Subject: Re: Babylon
Date: 22 Feb 2011 11:54:44
Message: <4d63ea54$1@news.povray.org>
Am 22.02.2011 13:40, schrieb Zeger Knaepen:
I do. Incredible, to think that you did that in just about 2 months' time!
Date: 22 Feb 2011 12:40:01
Message: <web.4d63f4a3d2a948c094d713cc0@news.povray.org>
> cu!
> ZK
Wow, that is really cool! All POV-Ray?
www.McGregorFineArt.com
Date: 22 Feb 2011 13:04:22
Message: <4d63faa6$1@news.povray.org>
It gets my vote.
Regards
Date: 22 Feb 2011 14:10:58
Message: <4d640a42$1@news.povray.org>
Yes, very impressive! I especially like the atmospheric
light effects and the water waves.
Two minor nitpicks:
Some camera rotations look a bit distorted to me, e.g. at 6:10.
Possibly a projection effect due to wide angles?
Even dense asteroid regions usually have distances of hundreds
of thousands of kilometers between individual asteroids, but that
is a common misrepresentation in popular science fiction as well ;)
Date: 22 Feb 2011 16:57:05
Message: <4d643131$1@news.povray.org>
> cu!
Great :)
I like your destination planet. I think that's the most alien habitable
world I ever saw, while been strangely beautiful.
I concord about the asteroids. I must add that a space flotila would
very probably travel with the various ships separated by at least 100Km.
When you travel at over 300 km/s, such a flight formation can be
qualified *tight*!
But, then, you no longer have anything to see... and visualy, that's bad.
Date: 22 Feb 2011 18:32:33
Message: <4d644791$1@news.povray.org>
> I do.
thanks! :)
Well, I did use some (reworked) older work.  The planets (both earth and
the alien planet) for example are based on a planet-generator I made
years ago.  The lensflare was also designed years ago.
And also, most objects used are *extremely* simple.  I think none of the
scenes took more than 3 days to render, for sometimes up to 750 frames.
  I also used different tricks that allowed me to use a lower
AA-setting, like mipmapping, scaling things way too big to be realistic,
and using extremely simple textures for far away objects.
But still, I'm kinda proud of the result :)
cu!
ZK
Date: 22 Feb 2011 18:35:04
Message: <4d644828$1@news.povray.org>
thank you!
 > All POV-Ray?
Almost all POV-Ray. Obviously I used some photographs as backdrops for
the first few scenes, and also the glowing of the "wormhole" was done in
PP using Blender (I could have done it with POV-Ray though, but it would
have taken longer and looked worse).
cu!
ZK
Date: 22 Feb 2011 18:40:32
Message: <4d644970$1@news.povray.org>
thank you :)
the water is simply a plane with a moving granite normal :)
> Two minor nitpicks:
I agree, I probably should have redone that scene, because I also don't
really like the ground texture, or the lens flares there.
Oh well, maybe I'll do a remake sometime. Seems to work for hollywood
these days :)
I suppose so.
I know that :) But if you want realistic space scenes, they're gonna be
quite boring :)
So it's more of an artistic choice rather than a real mistake :)
cu!
ZK
Date: 22 Feb 2011 18:41:49
Message: <4d6449bd$1@news.povray.org>
On 22/02/2011 22:57, Alain wrote:
> Great :)
Nice to hear that :) thank you!
Original concept was way more alien, but that would have taken far too
long :)
> qualified *tight*!
exactly! :)
cu!
ZK
