Since mid december I've been working on an animated music-video. The
music was made a couple of years ago, the animation was finished about a
week ago. Here's the result:
http://www.youtube.com/watch?v=oAckZrhGN3U
I hope you all like it!
cu!
ZK
Am 22.02.2011 13:40, schrieb Zeger Knaepen:
I do. Incredible, to think that you did that in just about 2 months' time!
> cu!
> ZK
Wow, that is really cool! All POV-Ray?
www.McGregorFineArt.com
It gets my vote.
Regards
Yes, very impressive! I especially like the atmospheric
light effects and the water waves.
Two minor nitpicks:
Some camera rotations look a bit distorted to me, e.g. at 6:10.
Possibly a projection effect due to wide angles?
Even dense asteroid regions usually have distances of hundreds
of thousands of kilometers between individual asteroids, but that
is a common misrepresentation in popular science fiction as well ;)
> cu!
Great :)
I like your destination planet. I think that's the most alien habitable
world I ever saw, while been strangely beautiful.
I concord about the asteroids. I must add that a space flotila would
very probably travel with the various ships separated by at least 100Km.
When you travel at over 300 km/s, such a flight formation can be
qualified *tight*!
But, then, you no longer have anything to see... and visualy, that's bad.
> I do.
thanks! :)
Well, I did use some (reworked) older work. The planets (both earth and
the alien planet) for example are based on a planet-generator I made
years ago. The lensflare was also designed years ago.
And also, most objects used are *extremely* simple. I think none of the
scenes took more than 3 days to render, for sometimes up to 750 frames.
I also used different tricks that allowed me to use a lower
AA-setting, like mipmapping, scaling things way too big to be realistic,
and using extremely simple textures for far away objects.
But still, I'm kinda proud of the result :)
cu!
ZK
thank you!
> All POV-Ray?
Almost all POV-Ray. Obviously I used some photographs as backdrops for
the first few scenes, and also the glowing of the "wormhole" was done in
PP using Blender (I could have done it with POV-Ray though, but it would
have taken longer and looked worse).
cu!
ZK
thank you :)
the water is simply a plane with a moving granite normal :)
> Two minor nitpicks:
I agree, I probably should have redone that scene, because I also don't
really like the ground texture, or the lens flares there.
Oh well, maybe I'll do a remake sometime. Seems to work for hollywood
these days :)
I suppose so.
I know that :) But if you want realistic space scenes, they're gonna be
quite boring :)
So it's more of an artistic choice rather than a real mistake :)
cu!
ZK
On 22/02/2011 22:57, Alain wrote:
> Great :)
Nice to hear that :) thank you!
Original concept was way more alien, but that would have taken far too
long :)
> qualified *tight*!
exactly! :)
cu!
ZK
