POV-Ray : Newsgroups : povray.binaries.animations : PoVSolar: new animation Server Time
31 Oct 2024 16:14:13 EDT (-0400)
  PoVSolar: new animation (Message 1 to 5 of 5)
Subject: PoVSolar: new animation
Date: 13 May 2009 18:39:13
Message: <4a0b4c11$1@news.povray.org>
High!
A flight around Jovian moon Amalthea:
http://www.youtube.com/watch?v=iGbcV5yqgRM&feature=channel
See you on www.khyberspace.de!
Yadgar
Subject: Re: PoVSolar: new animation
Date: 24 May 2009 08:10:33
Message: <4A193931.2050506@hotmail.com>
I think that if the sum lit jupiter I would expect it to light the moon
also in some comparable way. And I would expect to be blinded at some
point by the sun. What about the light that comes off off jupiter, I
assume you didn't use radiosity.
> High!
> Yadgar
Date: 30 May 2009 14:48:35
Message: <4a217f83@news.povray.org>
High!
It is lit in a comparable way - but Amalthea's surface is very dark
(albedo 0.09)!
> point by the sun.
 From Jupiter, the sun appears only one fifth as large as from Earth...
so at first, I even wondered whether it would show up at all - it's
hardly discernible from the background stars! Perhaps using Chris
Colefax' lens flare macros could help...
In fact I did! But, as I mentioned before, Amalthea is very dark...
See you in Khyberspace!
Yadgar
Date: 30 May 2009 21:41:20
Message: <4a21e040$1@news.povray.org>
Jörg 'Yadgar' Bleimann nous illumina en ce 2009-05-30 14:48 -->
> High!
>> moon also in some comparable way.
> (albedo 0.09)!
A piece of coal may have a larger albedo!
>> And I would expect to be blinded at some point by the sun.
> Yadgar
Amalthéa is so dark, that you'd make it brighter by painting it all over with
your usual black paint. ;)
I think that Pluto's albedo is even lower...
Date: 31 May 2009 10:27:10
Message: <4a2293be$1@news.povray.org>
actually, Pluto seems to be rather on the bright side of life as
concerns the albedo (about 0.5 with high variabilty across surface,
higher than Earth, according to most sources I could find). Of course,
it doesn't really get a lot of sunlight to appreciate it ;)
