POV-Ray : Newsgroups : povray.binaries.animations : Ocean waves (WIP) Server Time
11 Oct 2026 21:41:53 EDT (-0400)
  Ocean waves (WIP) (Message 1 to 21 of 21)
Subject: Ocean waves (WIP)
Date: 22 Jan 2009 17:34:11
Message: <4978f463$1@news.povray.org>
Hi, all.
The other day I had an idea of how to make realistic animated ocean
waves. Now I have implemented a first version of it and it turned out
quite well. It's not finished, I still have some things to try. It also
needs a better material.
Animation: http://www.daniel-nilsson.com/ocean01.mpg (1.6Mb)
Statistics: http://www.daniel-nilsson.com/ocean01.txt (for 250 frames)
The ocean surface is a mesh2 generated from a parametric surface defined
by three functions: x(u,v,t), y(u,v,t), z(u,v,t). I tried to use a
parametric object instead of mesh but it is much slower and looks no
better. The material is a uv mapped texture map using a function pattern
that controls the amount of foam.
There is no data saved between frames, no slow simulations, just
functions. It actually rendered much faster then I though it would,
almost 10 frames/minute on one core of my core2 quad @2.4GHz for 320x240
and no aa.
I'll post the code when it is finished and cleaned up.
Daniel Nilsson
Subject: Re: Ocean waves (WIP)
Date: 22 Jan 2009 19:35:00
Message: <web.49790fe645771519a7aaf540@news.povray.org>
Hum... Media Player won't play media...
Date: 22 Jan 2009 22:05:09
Message: <497933e5@news.povray.org>
clipka nous illumina en ce 2009-01-22 19:31 -->
Same thing here. Refuse to play.
Where the press is free and every man able to read, all is safe.
Thomas Jefferson
Date: 22 Jan 2009 22:35:47
Message: <49793b13@news.povray.org>
Try right-click on link, save to desktop, then play it from there. Works
OK for me.
Jack
Date: 23 Jan 2009 04:55:01
Message: <web.497992fe45771519a7aaf540@news.povray.org>
Glad to here it's not just my MP being crapped up again... had a problem
recently with that "alien in the park" movie, where my MP wouldn't install a
proper codec automatically for some stupid reason, so I had to find out how to
do that manually.
Message: <web.497993ae45771519a7aaf540@news.povray.org>
> OK for me.
Was the first thing I did when it didn't play right from the net. No-go though.
Date: 23 Jan 2009 09:13:05
Message: <g1kjn4tcpt8kkrjkkp2id3v9v1aelm98b8@4ax.com>
>> OK for me.
VCL Media Player plays just about anything even broken downloads.
Regards
Date: 23 Jan 2009 11:42:28
Message: <4979f374$1@news.povray.org>
Hmm, I encoded it with mencoder in linux with some settings I found on
the net. If someone can tell me some working options I'll use them.
Otherwise I will experiment some and test in windows before posting the
next time. I'm new to video encoding so I though that a MPEG-1 file is a
MPEG-1 file, and works everywhere. Obviously, that's not the case.
Daniel Nilsson
Date: 23 Jan 2009 12:40:01
Message: <web.497a00a24577151bdc576310@news.povray.org>
Thanks for the advice, but I'd like to stick to WMP if it can be helped.
Date: 23 Jan 2009 12:50:01
Message: <web.497a031a4577151bdc576310@news.povray.org>
That's what I thought as well - and I also thought that a .wma file is a .wma
file... but WMP keeps giving me painful lessons on this topic :-/
Date: 23 Jan 2009 13:33:39
Message: <497a0d83$1@news.povray.org>
  Purely out of curiosity: Why?
  (I ask this because it makes little sense to me. VLC, like mplayer, is
quite notorious for its extensive and high-quality support for a very
wide variety of video and audio formats, so there's a high probability
that it will play almost anything you throw at it, if it's a video file.
And it's not like it would *replace* WMP. You would have it alongside
it, so you can always *choose* which one to use. Thus I honestly don't
see any logical reason to avoid trying VLC.)
Date: 23 Jan 2009 15:47:37
Message: <b6bkn4p6o89ppc693764rs926hhf33d5rf@4ax.com>
Like Warp said, you can use it alongside your usual app. I do.
Regards
Date: 23 Jan 2009 16:10:00
Message: <web.497a30db4577151f50167bc0@news.povray.org>
It comes up in Quicktime on my Windows XP SP3, and plays OK.  But I've forgotten
how I changed the default MPEG player to QT. :-(  WMP gives me trouble with some
other formats, too. (BTW, I downloaded the xvid codec package today; will be
using that from now on to compress my own animations into MPEG. Seems to be of
excellent quality.)
I like the animation, especially the look of the foam. My only suggestion would
be to speed up the action 2-3 times. Kind of slow as-is.
Ken W.
Date: 23 Jan 2009 16:55:00
Message: <web.497a3bd44577151bdc576310@news.povray.org>
Exactly because of that: I do not *want* two things for the same job. Probably
because I'd hate having to adapt to different UIs on a daily basis.
And, having all my mp3 collection in WMP's media library, and having gotten
accustomed to how it's operated, I'd prefer that one single thing to be the
WMP, not some new piece of software.
Date: 23 Jan 2009 22:52:40
Message: <497a9088$1@news.povray.org>
>>> OK for me.
Yeah. I forgot to mention that I was using VLC.
Jack
Date: 23 Jan 2009 23:30:00
Message: <web.497a98b9457715118134d760@news.povray.org>
Works nicely here both from within Firefox itself or with Totem, let alone more
robust Mplayer and Vcl.  The WMP in my father's older XP box wouldn't even play
mp3, a barebones piece of crap. :P
Date: 23 Jan 2009 23:35:00
Message: <web.497a9a30457715118134d760@news.povray.org>
No, he can't.  He's on a moral crusade about the immoral FSF advances. ;)
Date: 24 Jan 2009 06:58:16
Message: <497b0258$1@news.povray.org>
  Well, if you willingly want to succumb to resistance to change, then I
suppose you'll have to suffer WMP's deficiencies.
  It still doesn't make sense to me, but that's just me.
Date: 24 Jan 2009 07:40:01
Message: <web.497b0b55457715144fa40c50@news.povray.org>
:P
No, he's just too lazy to learn the UI of two apps doing just about the same.
Date: 24 Jan 2009 07:45:01
Message: <web.497b0d38457715144fa40c50@news.povray.org>
I imagine it's just perfectly normal inertia as one grows older... (can't
compete with some other guys here yet, but anyway, me I've never been older
before than today :))
Date: 24 Jan 2009 19:50:00
Message: <web.497bb6734577151f50167bc0@news.povray.org>
Oops, I forgot to mention that I'm using Firefox.
KW
