Hi, all.
The other day I had an idea of how to make realistic animated ocean
waves. Now I have implemented a first version of it and it turned out
quite well. It's not finished, I still have some things to try. It also
needs a better material.
Animation: http://www.daniel-nilsson.com/ocean01.mpg (1.6Mb)
Statistics: http://www.daniel-nilsson.com/ocean01.txt (for 250 frames)
The ocean surface is a mesh2 generated from a parametric surface defined
by three functions: x(u,v,t), y(u,v,t), z(u,v,t). I tried to use a
parametric object instead of mesh but it is much slower and looks no
better. The material is a uv mapped texture map using a function pattern
that controls the amount of foam.
There is no data saved between frames, no slow simulations, just
functions. It actually rendered much faster then I though it would,
almost 10 frames/minute on one core of my core2 quad @2.4GHz for 320x240
and no aa.
I'll post the code when it is finished and cleaned up.
Daniel Nilsson
Hum... Media Player won't play media...
clipka nous illumina en ce 2009-01-22 19:31 -->
Same thing here. Refuse to play.
Where the press is free and every man able to read, all is safe.
Thomas Jefferson
Try right-click on link, save to desktop, then play it from there. Works
OK for me.
Jack
Glad to here it's not just my MP being crapped up again... had a problem
recently with that "alien in the park" movie, where my MP wouldn't install a
proper codec automatically for some stupid reason, so I had to find out how to
do that manually.
> OK for me.
Was the first thing I did when it didn't play right from the net. No-go though.
>> OK for me.
VCL Media Player plays just about anything even broken downloads.
Regards
Hmm, I encoded it with mencoder in linux with some settings I found on
the net. If someone can tell me some working options I'll use them.
Otherwise I will experiment some and test in windows before posting the
next time. I'm new to video encoding so I though that a MPEG-1 file is a
MPEG-1 file, and works everywhere. Obviously, that's not the case.
Daniel Nilsson
Thanks for the advice, but I'd like to stick to WMP if it can be helped.
That's what I thought as well - and I also thought that a .wma file is a .wma
file... but WMP keeps giving me painful lessons on this topic :-/
