POV-Ray : Newsgroups : povray.binaries.animations : A*C + (1-A)*B Server Time
27 Nov 2026 13:09:54 EST (-0500)
  A*C + (1-A)*B (Message 1 to 11 of 11)
Subject: A*C + (1-A)*B
Date: 9 Aug 2007 18:20:56
Message: <46bb9348@news.povray.org>
The final shot.
John
Download 's018f.mpg' (236 KB)
Subject: Re: A*C + (1-A)*B
Date: 10 Aug 2007 09:30:30
Message: <c3qob3dji9i45flfrjdlbp16fngtejgo75@4ax.com>
Cool!
Date: 10 Aug 2007 14:05:00
Message: <46bca8cc$1@news.povray.org>
I agree - very VERY nice technique :)
"Kyle" <hob### [at] gatenet> wrote in message
news:c3qob3dji9i45flfrjdlbp16fngtejgo75@4ax.com...
> Cool!
Date: 10 Aug 2007 14:58:07
Message: <46bcb53f@news.povray.org>
"John VanSickle" <evi### [at] hotmailcom> wrote in message
news:46bb9348@news.povray.org...
> The final shot.
    Love it! Although, I'm wondering about the grey, (and maybe what else
you could do with it - or is that a secret?)  ;)
      ~Steve~
> Regards,
> John
Date: 10 Aug 2007 21:55:08
Message: <46bd16fc@news.povray.org>
>>The final shot.
I have used this technique before.  In "Cliffhanger" (October 2002) and
"Dueling Empires" (Oct 2004) which was my October 2004 entry, I used the
same technique to create the shots where the Greb ships fly into the
warp gate into warp space, or out of a warp gate into normal space.
In these, Shot B was a view of normal space (with the ring that forms
the edge of the warp gate), Shot C was exactly the same, except that the
background was the red-and-black of warp space, and shot A was the mask
that exactly covered the area of the screen contained by the warp gate's
edge.  Also, some #if-#end blocks controlled whether ships were in the
shot or not, so that a ship that went into the gate appeard to enter or
leave warp space in a believable fashion.
In "Showbots" (July 2000), "A Bold Adventure" (Jan 2005), and "Top Ten
List" (Jan 2007), I used the same technique to do the digital censoring
of the caseless robots.  Shot B was rendered at 320x240, shot C was
rendered at 40x30, and Shot A consisted of the censored models, rendered
fully white against a black background, rendered at 40x30.
The only thing to remember is that the objects which are present in both
the B and C shots MUST be positioned identically, relative to the
camera, and if the masking is based on the objects in the scene, then
the mask object must properly fit the objects in the scene, usually by
having the mask objects positioned, relative to the camera, in the same way.
Once you get that going right, the technique is really quite easy.
John
Date: 11 Aug 2007 00:26:22
Message: <46bd3a6e$1@news.povray.org>
news:46bd16fc@news.povray.org...
  Hey, I remember "Showbots" from when I got my first PC (end of '99) - I
think it's what led me on to POV-Ray.  :) I know this because I was really
impressed with John Wise' "That's Impossible" animation. Animations took
forever to download back then... ;)
> List" (Jan 2007), I used the same technique to do the digital censoring of
   Ah, I was wondering about that!
> rendered at 40x30,
   40x30 ?? Why that size? Speed?
> the B and C shots MUST be positioned identically, relative to the camera,
> and if the masking is based on the objects in the scene, then the mask
> object must properly fit the objects in the scene, usually by having the
   Phew! I was going to mention in my first reply that 'masks' were possibly
used, but thought against it because it looked 'too neat'. Good job with
what you've done there John.
    I counted 36 animations on your website. I think I'll leave the
animations to you... Let's see double that number.   ;)
      ~Steve~
> Regards,
> John
Date: 11 Aug 2007 14:27:04
Message: <46bdff78$1@news.povray.org>
>> Shot B was rendered at 320x240, shot C was rendered at 40x30,
No, to produce the blockyness.  I used mega anti-aliasing and rendered
the exact same scene at lower resolution; when scaled back up to 320x240
in the masking render, it produced a shot in which each 8x8 block of
pixels was a solid square colored to match the average of the same block
of pixels from Shot B.
It's actually quite easy to make sure that everything is positioned
right, relative to the camera; simply cut and paste the scene code for
the positioning of the camera and the objects.
It was slightly trickier with the scene above, because for shots A and B
the models and the camera are positioned exactly, but for shot C the
scene required that the robots be turned 90 degrees clockwise and
translated by <-5000,-10,15500>; but the transform only had to be
applied in four places in the .INC file, so it wasn't that hard.
I'm working on it.  My next one is already up to 1440 frames (a full
minute), and it will probably be closer to two minutes when I'm done.
John
Date: 15 Aug 2007 07:40:00
Message: <web.46c2e5f8f080f6398d92e1a00@news.povray.org>
> Regards,
> John
I'm wondering why you haven't placed your animation for the 'Dance' round on
your website.
Also, I like that animation of yours.  I always use texture_maps to do most
of my fading, with usually bozo or waves for the best effect.
  --Nimish
Date: 17 Aug 2007 17:07:53
Message: <46c60e29@news.povray.org>
> your website.
I generally don't put them on my geocities page until the round has been
voted on.  I suppose that I could make an exception for this round...
John
Date: 17 Aug 2007 21:40:01
Message: <web.46c64c98f080f6398d92e1a00@news.povray.org>
> > your website.
Well, this is a non-voting round. :)
> Regards,
> John
One quick question.  For the application of the mask, do you do it directly
in Pov-ray or is it post-processed in a movie editor?
  --Nimish
Date: 21 Aug 2007 18:51:45
Message: <46cb6c81@news.povray.org>
>>>your website.
>>Regards,
>>John
The processing is done with POV-Ray code.  I make a pigment from the
mask, and then use that pigment in a pigment_pattern type pigment, with
the start and end shots in the pigment_map.
Works nicely.
John
