POV-Ray : Newsgroups : povray.binaries.animations : A new idea or old hat... Server Time
22 Jan 2025 08:44:28 EST (-0500)
  A new idea or old hat... (Message 1 to 5 of 5)
Subject: A new idea or old hat...
Date: 30 May 2007 10:27:46
Message: <465d89e2@news.povray.org>
Not sure if this is a shiny new idea or if everyone knows it and doesn't
even bother mentioning it...
I was wondering about changing an image_map over time and the idea came to
me to use the output from one rendering as the image_map for another (I
think you can probably get some good animation effects by using the last
rendered frame every time...)
Anyway, as a simple showcase, I took the Apollo 13 video clip that ships
with vista and made it into a flat-screen tv (ok, a very shallow cube with
roudned edges... :D - Use your imagination)
The clip can be seen here:
http://www.youtube.com/watch?v=AzTjLQrfWB8 (I've had to use youtbue as high
compression makes the video unwatchable and low compression is far too big
to share here - so I'll let youtube worry about the encoding :D)
I'd appreciate any thoughts or ideas.
Simon
P.S. I know the sound is slightly out of sync - about 5 secs over the course
of the clip - This is due to me using the wrong frame rate while rendering
the scene - it should have matched my original video clip. - I couldn't be
bothered to wait for another 3544 frames to render :D
Subject: Re: A new idea or old hat...
Date: 30 May 2007 12:08:36
Message: <465da184@news.povray.org>
There's a sample scene called "Desk.pov" in the "Advanced" folder that
uses animation settings to create a framed picture containing a picture
of the the picture of the picture...I'd say there's a lot of potential
here for interesting images and/or animations.
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 30 May 2007 12:27:53
Message: <465da609@news.povray.org>
Well, that's crushing :) Oh well, I'm sure i can come up with something
interesting :D
Thanks for the reply
S
"Sherry Shaw" <tenmoonsPutAtCharacterHereaol-dot-com> wrote in message
news:465da184@news.povray.org...
> uses animation settings to create a framed picture containing a picture of
> the the picture of the picture...I'd say there's a lot of potential here
> --Sherry Shaw
Date: 30 May 2007 16:20:01
Message: <web.465ddc1eb6fed772bd61fc7e0@news.povray.org>
haha. i like the part in the vid where you see the screen from the back for
seconds and seconds and someone's still talking like real serious.
i'm glad i get another chance to mention this glorious animation i did
recently:
saveacopyUSA
http://www.youtube.com/watch?v=s_35zOFkgs0
somewhere in the middle there's this place with lots of TV's. some show the
MGM logo or the video propaganda in the beginning of '1984'. some fail to
sync and the pic is running through all the time, and i added some noise.
finally the cam zooms into a tv showing the last rendered frame and
everything dissolves into noise to make place for the next amazing scene---
Date: 31 May 2007 07:20:01
Message: <web.465eaee5b6fed7726d4565230@news.povray.org>
> me to use the output from one rendering as the image_map for another ...
> Regards,
> Simon
Funny you should use the word "hat".  A while back I was toying with the
idea of using POV-Ray to produce an "oracle deck" and used the idea for the
Magician card.
BTW, neat animation.  I can foresee many nifty applications for the
technique.  Spaceship bridges and "Mission Control " type scenes spring to
mind.
Mike C.
Download 'magiciancard.jpg' (101 KB)
Preview of image 'magiciancard.jpg'
Date: 1 Jun 2007 00:35:02
Message: <web.465fa100b6fed77257033b2e0@news.povray.org>
My first attempt at this was using a clip from the TV show "Airwolf" in
March 2000.  I came back to it in 2003 to make a "TV Wall" inspired by The
Matrix.  Check it out here:
http://mcnasobers.googlepages.com/mike%27sfunstuff
Looks great!  The possibilities are endless . . .
Mike S.
