Derived from the SCC WIP I posted in p.b.i a while ago, though obviously
this version uses a lot more than 256 bytes of code.
The animation is just a vturbulence function applied to the tops of the
grass blades (cones), with the turbulence moved over time.
Tek
http://evilsuperbrain.com
Download 'grassy.m1v.mpg' (658 KB)
Less compressed version here (about 1.6MB):
http://evilsuperbrain.com/gallery/wip/index.php?movie=grassy_hq
Tek
"Tek" <tek### [at] evilsuperbrain com> wrote in message
news:4531f967@news.povray.org...
> Tek
Nice one! Although, that is a very *strong* wind.
~Steve~
> Tek
That's awesome!
Was the rendering time ok?
(Considering you said something about using cones.)
Should be neat flying past an animated field blowing in the wind like that.
Rendering time wasn't great 'cause I need high anti-alias settings and the
scene takes a few seconds to parse, so it took about 7 hours for 200 frames.
Not ideal but certainly useable.
The problem with flying past is that the area is relatively small, what
looks like the crest of a hill is actually the limits of the grassy area
I've created, so when I rigged up a version that would move that area with
the camera (so we never get closer to the far edge as we fly through the
field) you can really badly see ground popping in at that distance. To hide
this effect I'd need many times more grass, which would make it render many
times slower... sigh...
Tek
"RusHHouR" <gee### [at] mail nu> wrote in message
news:web.4534eae6ab8d2f9647d3ae5e0@news.povray.org...
> That's awesome!
> that.
> Tek
Ah, I see.. :/
How many grass cones/units are there then in this version?
news:web.453677b1ab8d2f9647d3ae5e0@news.povray.org...
it's a 128x128 grid, so 16,384.
Tek
Tek nous apporta ses lumieres en ce 17/10/2006 11:56:
Maybe you can hide that with some fog. Another avenue would be to make the
ground much larger and use some faked grass outside the area actualy covered by
your grass.
Impressionism: From a distance, shit looks like a garden.
I think fake grass would be the best option, otherwise I'd need fog so dense
you could only see a distance of 128 blades of grass, which in real world
terms would be maybe a couple of meters, now that's foggy! :)
Tek
"Alain" <ele### [at] netscape net> wrote in message
news:4536cc6d$1@news.povray.org...
>> the scene takes a few seconds to parse, so it took about 7 hours for 200
>> frames. Not ideal but certainly useable.
>> with the camera (so we never get closer to the far edge as we fly through
>> the field) you can really badly see ground popping in at that distance.
>> To hide this effect I'd need many times more grass, which would make it
>> render many times slower... sigh...
> covered by your grass.
> Alain
What about spreading the grass out just a little with fake grass in between?
Or thin it out towards the edges, fading to dirt/gravel/whatever was you
leave the grassy area? Like a small grassy areas forgotten & idle in the
middle of suburbia? Or those creek areas we all used to play in as kids ;)
news:45375c50@news.povray.org...
>dense you could only see a distance of 128 blades of grass, which in real
>world terms would be maybe a couple of meters, now that's foggy! :)
> Tek
>>> through the field) you can really badly see ground popping in at that
>>> distance. To hide this effect I'd need many times more grass, which
>>> would make it render many times slower... sigh...
>> the ground much larger and use some faked grass outside the area actualy
>> Alain
Well if I was creating a scene to look totally real I'd have started with
something better than this, which would be capable of filling a scene
without needing huge render times. The reason this isn't very efficient is
it was created for the short code contest and then I animated it out of
curiosity. Short code tends to require brute force solutions. So what I'm
saying is that despite the speculation in this discussion I have no desire
to find an efficient way to do this effect, because the basic effect is not
intended to be any good in the first place!
Anyway, if I were to start from scratch I'd probably modify the turbulence
function to repeat itself, then generate a square patch of grass blowing in
the wind (as a mesh of triangular blades, for speed), then create multiple
instances of this spread through the world since that takes almost no
processing time. This also lets me use a trick I've done before of shading
the blades so they have fuzzy edges, meaning anti-aliasing is less of an
issue. Only problem is a tiled pattern can look a bit obvious, so I'd need
to break it up with a few non-repeating features dumped in on top...
hmm... that's sounding quite tempting now...
Tek
"Data Banks" <da_### [at] ihug com au> wrote in message
news:4537f4e8@news.povray.org...
> between? Or thin it out towards the edges, fading to dirt/gravel/whatever
> was you leave the grassy area? Like a small grassy areas forgotten & idle
> in the middle of suburbia? Or those creek areas we all used to play in as
> kids ;)
>> Tek
>>>> 200 frames. Not ideal but certainly useable.
>>>> area I've created, so when I rigged up a version that would move that
>>>> area with the camera (so we never get closer to the far edge as we fly
>>> Alain
Tek nous apporta ses lumieres en ce 20/10/2006 08:47:
You can then use a few different tiles (2 to 4), randomly select, rotate and
mirror them before you translate them to the final position.
Those tiles can have some fuzzy edges and the placement overlaps in those areas.
Gravity is a Myth. The Earth Sucks!
> and mirror them before you translate them to the final position.
> those areas.
You have to be careful with the movement of the wind, though.
To look _really_ good, you'd apply the wind after the placement of the
tiles, which would of course eliminate the usefulness of the tiles.
Applying the wind _before_ placement means you can't rotate every which
way...
It's a tough one.
...Chambers
