POV-Ray : Newsgroups : povray.binaries.animations : something I've been working on (MPEG1, 468KB) Server Time
12 Oct 2025 04:43:48 EDT (-0400)
  something I've been working on (MPEG1, 468KB) (Message 1 to 10 of 13)
Subject: something I've been working on (MPEG1, 468KB)
Date: 13 Oct 2006 14:19:34
Message: <452fd8b6@news.povray.org>
I call it a "Particlesystem" ! :)
no, seriously.  I had to make my own particlesystem, because apparently
there's no way to randomize Rune's particle-system (the variable
particle_seed is never used, you might want to look into that, Rune :))
and I couldn't just change it in his code or I would have to release it
under the GPL, which I don't like (GPL is like a virus: everything that
uses something that has it, becomes a GPL'ed thing itself).
So, the basic principles are the same as in every particle-system: you
have a particle-emitter which, you'll probably never guess, emits
particles! :)  those particles have a starting speed and are affected by
outside forces, like gravity.  There's also a possibility to add an
environment, and as you can see in this animation, it's also possible to
let the particles "flow" along the surface of the environment.  It has
no particle-particle interaction, so it's impossible to accurately model
fluids with it, but as you can see here, it can produce fluidlike
animations :)
As with all my include files, it's not yet finished and maybe never will
be :-/
it all depends on how much demand there is for yet another particle
system.
cu!
Download 'particlesystem.m1v.mpg' (469 KB)
Subject: Re: something I've been working on (MPEG1, 468KB)
Date: 13 Oct 2006 14:47:14
Message: <452fdf32@news.povray.org>
and another, hotter, demo-animation
cu!
Download 'circularfire.m1v.mpg' (469 KB)
Date: 13 Oct 2006 15:32:42
Message: <452fe9da@news.povray.org>
> no, seriously.  I had to make my own particlesystem, because apparently there's no
way to randomize Rune's particle-system (the variable particle_seed is never used, you
might want to look into that, Rune :)) and I couldn't just change it in his code or I
would have to release it under the GPL, which I don't like (GPL is like a virus:
everything that uses something that has it, becomes a GPL'ed thing itself).
> So, the basic principles are the same as in every particle-system: you have a
particle-emitter which, you'll probably never guess, emits particles! :)  those
particles have a starting speed and are affected by outside forces, like gravity.
There's also a possibility to add an environment, and as you can see in this
animation, it's also possible to let the particles "flow" along the surface of the
environment.  It has no particle-particle interaction, so it's impossible to
accurately model fluids with it, but as you can see here, it can produce fluidlike
animations :)
> As with all my include files, it's not yet finished and maybe never will be :-/
> it all depends on how much demand there is for yet another particle system.
Looks nice, especially that fiery animation is great, care to share the
particle's setup (I'm guessing discs with a neatly animated pigment)?
But, I also have to admit that I'm a little sad that you overlooked my
particle-system. It's entirely flexible, you can add as many objects as
you like for interaction, there's no particle-particle-interaction, but
hey, you can call macros for when objects get hit, you can add your own
variables to attach to the macros in case you want to animate them in
some special way with your own macros...
I guess I have to be more offensive about my Include-Files. I need a
better marketing concept...
Tim
aka "Tim Nikias"
Date: 13 Oct 2006 16:23:03
Message: <452ff5a7$1@news.povray.org>
"Tim Nikias" <JUS### [at] gmxnetWARE> wrote in
message news:452fe9da@news.povray.org...
the
tnx :)
yes, the fire and smoke are just discs using these macros as a pigment:
-- begin code --
//Slime's code :)
#macro Additive_Blend(Color)
 #local Additiveness=1.00001;
 #local Color = <1,1,1> * Color / (1 - Additiveness);
 rgbt <Color.x, Color.y, Color.z, Additiveness> //Transparency + (1 -
Transparency) * Additiveness>
//smoke
#macro RookPigment(T,TR)
  pigment_pattern {
   function {max(min(x,1),0)}
   translate -x*.5
   scale sqrt(2)
   rotate y*45
  color_map {
   [0 rgb .0125 transmit T]
   [1 rgb .5 transmit T]
  translate -TR
  warp {turbulence .25 lambda 3}
  translate TR
//fire
#macro VuurPigment(T,TR)
 pigment_pattern {
  granite
  scale 16
  color_map {[0 rgb 0][1 rgb 1-T]}
  warp {turbulence 1.5}
  translate y*clock*2
 color_map {
  [0 Additive_Blend(0)]
  [.5 Additive_Blend(<1,.45,.2>*.5)]
  [1 Additive_Blend(<1,.65,.4>*2)]
 translate -TR
 translate TR
//a macro for animating 'flashes'
#macro flash(T,P,Grens)
  #if (T<Grens)
    #local T=1-(T*(1/Grens));
  #else
    #local T=(T-Grens)/(1-Grens);
  #local R=pow(T,P);
  R
  #declare Seed2=seed(pID+10);
//a firey disc,
// pStatus is the status of the particle, where pStatus=0 at it's
birth and 1 when it dies
// pLocation is the location of the particle
  disc {
   0,y,1
    #local Translate=rand(Seed2)*500;
    pigment_pattern {spherical poly_wave 2}
    pigment_map {
     [0 VuurPigment(1,Translate+z*clock*.5)]
     [1 VuurPigment(flash(pStatus,2,.0625),Translate+z*clock*.5)]
   finish {ambient 1}
    Point_At_Trans(Camera_Lookat-Camera_Location)
    scale (3-2*pStatus)/15
    translate pLocation
    no_shadow
//and a smokey disc
  disc {
   0,y,1.5
    pigment_pattern {spherical poly_wave 1}
    pigment_map {
     [0 RookPigment(1,Translate+z*clock*.5)]// scale .5]
     [1 RookPigment(flash(pStatus,1,.3),Translate+z*clock*.5)]// scale
.5]
    translate Translate
    warp {turbulence .5 lambda 3}
    translate -Translate
   finish {ambient 1}
    scale (3+4*pStatus)/20
    translate pLocation
    no_shadow
-- end code --
(something like that :))
as
but
own
hmm, sounds interesting and worth checking out !
let's see :p
hmm, looks good! I like the particle-splitting-on-collision-feature :)
I'm thinking about how to add that to my system :p
hmm, dunno
but, let's do some google-testing:
searching for: povray "particle system"
gives Rune's website before your site :-/ Even Chris Colefax's website
comes before yours, and he doesn't seem to have made anything new in 2
years :(
however, searching for: povray particles
gives first Colefax's site, then, at the bottom of the first page, your
page directly followed by Rune's page
if I search for: povray particle
then Rune's site is the first hit, Colefax's site the second, and you're
not even on the first page (????)
so, for some reason, google likes Rune's site more than your site, which
is why I overlooked your site.  My apologies :)
(but I would have made my own system anyway, it's just too fun to do
things yourself imho :))
(btw, I just noticed: all these searches are apparently done while being
signed in to Google, so they might be personalised search-results)
cu!
Date: 13 Oct 2006 17:21:51
Message: <4530036f$1@news.povray.org>
> tnx :)
SNIP
Thanks, that'll be worth looking into (I always like to toy around with
procedural textures). :-)
> let's see :p
> hmm, looks good! I like the particle-splitting-on-collision-feature :) I'm thinking
Yeah, "do it yourself" is something I enjoy as well. It's just that when
you put a lot of effort into creating a system stable and versatile
enough so that others might benefit, it's kinda sad to see that no one
seems to use em. :-( Then again, Povers are often all about "do it
yourself", so maybe I'm just aiming at the wrong market. :-P
> hmm, dunno
SNIP
Hm, might be that the word "particle" isn't around on my page often
enough... Google also has this weighting algorithm, so I guess Chris
Colefax' site might be old, but is linked enough to be of weight, Rune's
is well spread as well, just look at the various other images that have
made use of his includes and thus link to him.
I'm guessing that I'm probably well-bookmarked (around 6000 visitors a
day), but badly linked, then add the missing usage of the word
"particle" and bingo, I'm lost on page 2... Like I said, I need a better
marketing strategy. Eh, I'll guess I'll put the word "particle" a dozen
of times on the page where the system will be downloadable... I'm
revamping my site, so that shouldn't be a problem. ;-)
Tim
aka "Tim Nikias"
Date: 13 Oct 2006 17:58:57
Message: <45300c21$1@news.povray.org>
"Tim Nikias" <JUS### [at] gmxnetWARE> wrote in message
news:4530036f$1@news.povray.org...
hmm, that's why I'm just making stuff for myself :)  then at least I know the
target-audience will use it :)
I'm not sure if just adding the word "particle" a couple of times will really
help :)
being linked to seems to be far more effective !
:) a while ago, if you used the image search on google to search for "atoombom"
(which means nuclear bomb in Dutch), the first hit was my nuclear explosion
image :)
so, I accomplished something in my life, I suppose :p
oh well, googleranking, it still confuses me :)
oh, take a look at that! apparently I'm the first hit again ! :)
cu! :)
Date: 13 Oct 2006 20:29:29
Message: <45302f69@news.povray.org>
> when you put a lot of effort into creating a system stable and
> versatile enough so that others might benefit, it's kinda sad to see
> that no one seems to use em. :-( Then again, Povers are often all
> about "do it yourself", so maybe I'm just aiming at the wrong market.
> :-P
I know that feeling...
Anyway, about the popularity and Google ranking, here's a few points to
consider:
- Showcase the system's usefulness, not its technical capabilities. For your
first particle system, I remember you spent a lot of time creating
animations with rainbow-colored bouncing balls and other things, and while
it's great eye-candy, it won't convince people that your system is useful
for their particular scene, since people rarely need lots of bouncing balls
and things like that. Cater to their needs and make it easy for them to see
that your system does exactly what they want for their scene.
- Making it easy to see that it is useful isn't enough either. Make it easy
to use too. I notice that your I/O particle system comes with only one
example animation which does take quite long to render and parse. I think a
lot of the popularity of my system is due to the fact that it includes no
less than 9 well documented example animations, all showcasing various
things that are often requested, and several of them are quick to parse and
render. They are even the same animations that are used to showcase the
system on the web page, so the users are shown exactly how to make
animations like those that attracted their attention in the first place.
- Make your system very visible on your website! Dedicating a page to the
system really makes it easier to notice, and to link to too! Your I/O
particle system is currently showcased in a small section at the bottom of
your download page and represented with two animations on your animations
page. It's rather easy to miss it, even when looking for it.
All three points will likely make more people use your system and link to it
if you are aggressive about it, while the last point will also make it more
attractive for Google. You can even have the word "particle" in the title of
the page then!
One thing to notice is that all this is a huge amount of work! I think I
spent 50% time on developing the features of the system and the other 50%
just on making it attractive and easy to use. It really requires effort. And
as you hinted, all this effort sometimes doesn't feel worth it in a
community where everyone prefers to reinvent the wheel anyway. For me, I'm
glad I put the effort into it, because it was a great learning experience to
not only develop but also "market" a system effectively, but I probably
wouldn't do it again to that extent for a POV-Ray include file.
Rune
http://runevision.com
Date: 13 Oct 2006 20:38:21
Message: <4530317d@news.povray.org>
Nice animation.
> apparently there's no way to randomize Rune's particle-system (the
> variable particle_seed is never used, you might want to look into
> that, Rune :))
That sound odd, but I don't have time to look into it right now (or probably
anytime soon).
> virus: everything that uses something that has it, becomes a GPL'ed
> thing itself).
You sound like it would be almost a brand new system if you fixed this bug
in my system, and you'd then have to release this "new" system under the GPL
too. That seems a bit odd to me.
Anyway, I was very reluctant in the beginning to release the system under
the GPL, but people in the POV community highly requested it (when the
alternative was a "not for commercial use" clause). I guess you can't please
everybody.
> will be :-/
> system.
Only time will tell.
Rune
Date: 14 Oct 2006 02:00:59
Message: <45307d1b@news.povray.org>
"Rune" <new### [at] runevisioncom> wrote in message
news:4530317d@news.povray.org...
> Nice animation.
thank you !
> > that, Rune :))
> anytime soon).
maybe I have an older version or something like that, never really bothered to
download your system again and double check it
> > thing itself).
no, but if I make something, anything, with your system, don't I have to release
that something under the GPL ?
oh, doesn't really matter, you know, the GPL and the problem with randomness
were just excuses to get me started on my own system :)
> everybody.
nobody ever can, but please don't take any of this as an insult or anything, I
just like to make my own stuff
cu!
Date: 14 Oct 2006 03:01:11
Message: <45308b37$1@news.povray.org>
> consider:
The "Rune-Three-Steps-To-Fame" program is set in my mind now, don't
worry. :-)
I've been rehauling my website lately (whenever I have the time for it),
and I've thought about introducing "R&D", aka Research and Development
as its own section. Research will cover things that are natively in
POV-Ray, like Radiosity and eventually Photons (the same questions come
up every now and then, so some research is in order), in Development
I'll showcase my Include-Files. And, like you said, instead of spreading
the animations, images and include-files across the entire site, I'll
more likely feature the particle-system on its own page, with links and
thumbnails to the various demonstrations I've got.
R&D might be a little confusing for those that don't yet know what to
expect behind it, but I guess after the initial confusion which my new
website will probably create anyway, it'll fit nicely. :-)
And yeah, I guess I should take a look at my demonstration file and
simplify it, aside of creating a few more...
Tim
aka "Tim Nikias"
