POV-Ray : Newsgroups : povray.binaries.animations : First post - animation Server Time
23 Feb 2025 23:30:18 EST (-0500)
  First post - animation (Message 1 to 10 of 12)
Subject: First post - animation
Date: 24 May 2006 10:38:28
Message: <44746fe4$1@news.povray.org>
So, you guys all wonder why I am here when I don't post any graphics files.
Well, since I'm very busy I don't get too much time to mess with POV-Ray
unless it is work related.
Here is an animation that another guy and I recently put together.
It isn't very artistic as we are both engineers and like the technical
aspects of the project better than the aesthetics :-)
The animation is of a very small area in an underground mine.
Look at features in the data to get a sense of scale of the place.
The ceiling is 50-70 feet high!
The sheer amount of data made this a challenging project because
iterations were not quick.
If we get more work here it will likely be 100x this amount of data...
gee I can't wait :-o
Anyway, come on over and have a gander
www.stineconsulting.com/junk/
LAter...   Tom
Subject: Re: First post - animation
Date: 24 May 2006 11:20:43
Message: <447479cb@news.povray.org>
Hi.
I would like to run the larger of the two animations, but I cannot play
files with the extension "*.m1v". Could you save it as AVI or MPG and use a
codec such as the new "MS MPEG4" codec? That would be great.
Greetings,
Sven
Date: 24 May 2006 12:50:21
Message: <44748ecd$1@news.povray.org>
"Tom Austin" <taustin> wrote in message news:44746fe4$1@news.povray.org...
Wow, this is fascinating.  How was the original data collected?
- How
Date: 24 May 2006 13:27:12
Message: <44749770$1@news.povray.org>
Hash: SHA1
Sven Littkowski wrote:
> Hi.
> Greetings,
	Rename the file to *.mpg and it will run. MPEG1 video will work on
a lot more platforms than MS MPEG4...
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2.2 (GNU/Linux)
iD8DBQFEdJdwd0kWM4JG3k8RAstvAKCK3XuonP9UBB97dgsKMMjkbStdvwCgpm3G
RhH89mvb2fHYYW1cJW63p+w=
=/lU2
-----END PGP SIGNATURE-----
Date: 24 May 2006 14:58:33
Message: <4474acd9@news.povray.org>
As per comments, the files have been renamed to .mpg.
Windows Media Player runs them fine on my PC here - I hope the same for you.
LAter... Tom
Date: 24 May 2006 15:04:11
Message: <4474ae2b$1@news.povray.org>
> - How
Thanks for the interest....
Using a 3D area laser scanner, separate 'scans' are collected at each
location.
This data is then 'aligned' together using various methods.
Then the aligned data is exported from the scanning software in vrml 3D
files (which closely match POV-Ray mesh2 format).
A custom routine makes the vrml into a mesh2.
This is done for *each* scan.
So in this animation you are looking at (9) separate mesh2 objects - one
for each scan.
If you look closely, small triangles are close to scan locations, and
large triangles are far away from a scan location.  They overlap nicely
as the alignment went fairly well.
At this time the data is not 'merged' into one cohesive dataset.
We've tried this in various ways only to fail each time.
If anyone has a suggestion on how to create one mesh, please let me know.
LAter... Tom
Date: 24 May 2006 15:55:52
Message: <4474ba48@news.povray.org>
"Tom Austin" <taustin> wrote in message news:4474ae2b$1@news.povray.org...
> location.
Forgive the questions, but:  What sort of laser, how long does a typical
scan take, and what's the maximum resolution?
> for each scan.
I don't suppose each scan has an absolute position reference?  You must know
something about their positions relative to each other, obviously, or you
wouldn't have been able to generate the fly-through like you did.
Warp has dealt with meshes quite a bit, perhaps he's got some ideas for
joining them together...
- How
Date: 24 May 2006 20:27:52
Message: <4474fa08$1@news.povray.org>
Because you requested MS MPEG4, I'm assuming you're using Windows.
Windows Media Player will play M1V files.  M1V is simply MPEG1.  The
reason its M1V and not MPG is that it is a video only file.
-DJ
> Hi.
> Greetings,
> Sven
Date: 25 May 2006 15:03:06
Message: <4475ff6a$1@news.povray.org>
>> location.
	It's a time of flight laser that can gather about 20,000 data points a
second.  It scans in a spherical grid (2 angles & a range).  The
scanning window is about 80 degrees vertical and 340 horizontal.
Each of the scans in this animation is over 2 million data points - each
raw scan file is over 17Mb.  A scan takes about 6 minutes to complete at
this resolution.  The data is good to about 1/2 inch.
We do not know anything about the positions of the scans in relation to
each other except a hand sketch for rough positioning.  We have some
software that neatly aligns the data automatically.  All we need to do
is give it a very rough starting point.
Using survey points, we were able to align the data in a real coordinate
system.
maybe....
LAter... Tom
Date: 26 May 2006 06:51:56
Message: <4476ddcc$1@news.povray.org>
"Tom Austin" <taustin> wrote in message news:4475ff6a$1@news.povray.org...
> second.  It scans in a spherical grid (2 angles & a range).  The scanning
Neat.  What type of laser is it?
> software that neatly aligns the data automatically.  All we need to do is
> system.
Wow, that's pretty slick.  How long does it take to parse and render a
single frame?
- How
